81' KZ750-4 valvetrain Question
- kzcafe750_24
Does anybody know if the stock intake and exhaust valves have satellite valve coating on them. I am just wondering, if I should replace the valves or can they be grinded. I know if you grind a valve that has satellite coating, the valve is junk. If anybody can give me some information on this or point me in the right direction that would be great.
Thanks,
1981 Kz 750-4 LTD - Wiseco 810 Big Bore,Ported cylinder head, GPZ 750 Cams,Dyna Ignition(DynaS,Green Coils,DRL400 2stage Revlimiter), RC 4 into 1 fitted with Yoshi muffler, ZR550 Swing arm, ZR550 Rear Rim, ZX750turbo front end SuperFlo Dyno Tuned- 68WHP&43WTq(ftlbs)
1986 Honda Rebel 250 (Stock)
1985...
- Motor Head
- Thank you received: 391
- steell
Check out the story at Wikipedia
- wireman
- Thank you received: 299
- Motor Head
- undiablo
- Thank you received: 64
Motor Head wrote: None that I know of. Very grindable, just check margin when done. You can get a full set of Stainless pretty cheap, $104 for 4 o Feebay from PSP.
Could you tell me where to buy a full set of 8 valves? I usually find them at Ebay, but not as a set... NOS are very high... Thanks!
Kawasaki KZ 750/4 LTD 1981
Kawasaki KLR 650 2011
Argentina - Buenos Aires
- Motor Head
Check PSP Ebay Store here. He should have a full set for your bike in stock, APE Valves.undiablo wrote:
stores.ebay.com/Pit-Stop-Performance-Sto...rksid=p2047675.l2563
- kzcafe750_24
Thanks Again,
1985...
