Oil from the carburetors
- KZJOE900
- Admin
I still suspect some kind of oil vapor pressure having to do with a malfunctioning breather. Any idea's anyone? Or am completely of track?
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
- KZJOE900
- Admin
"Bubbly is normal. Your oil is returned to the tank and gets pretty aerated. The oil retuirn line is at the top of the tank.
The oil supply line is off the bottom of the tank, so by the time top oil reaches the bottom, the bubbles are gone, or remain on top and are harmless. It's normal.
A tanish, milky "foam" is water mixed with oil.....common with cold weather riding, especially with a bike taken from a heated garage into cold temps. It will disappear after the engine is warmed and the moisture in the oil is "cooked" out and disepates via the head vents."
Today was the coldest I have ridden this bike, about 55 degrees. And was in the garage. O.K., so not worried about the foam and have never noticed it before. So I guess the oil in the carburetors is the main thing I need to concentrate on.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
- moneypit
- Thank you received: 35
2-76 kz900
St Paul MN
- KZJOE900
- Admin
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
- Thank you received: 2829
- Thank you received: 2098
Perhaps compression in at least one cylinder is low due to being lost into the crankcase and causing excessive pressure inside the crankcase which escapes through the breather hose exiting underneath the bike.KZJOE900 wrote: ... As for the breather, no air box but pods. I have routed the breather filter via a hose, same as the carb overflow hoses. So it now resides near the center stand.
Could help confirm such condition by performing a compression test on each cylinder, followed by a wet compression test on each cylinder.
Could also perform a leak down test -- even a poor man's leak down test would suffice -- to determine extent of blow-by from each combustion chamber into the crankcase, by listening to the volume of air escaping from the crankcase breather vent.
- KZJOE900
- Admin
I would guess that is the most probable situation. I know last I checked the compression was 115 all across. Haven't checked it since tearing the top end and putting it back together. I guess I will have to live with it until I install new piston and rings along with the required boring. That won't be until next summer. I may do the compression test and leak down test again just for kicks. I guess I was hoping it was something simpler like the breather itself. Thanks for the info Patton.
Ed, the oil I have in there is Valvoline motorcycle oil 10w 40. But if what I read on the net is correct, the foaming was due to moisture in the oil along with the warm / cold running of the bike. In other words, I started in a warm garage and rode in cool weather (50 to 55 degrees) for a 10 min ride. Not what I read is bs or not, but I am hoping the foaming is not an issue.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
- bountyhunter
- Thank you received: 337
KZJOE900 wrote: if what I read on the net is correct, the foaming was due to moisture in the oil along with the warm / cold running of the bike. In other words, I started in a warm garage and rode in cool weather (50 to 55 degrees) for a 10 min ride. Not what I read is bs or not, but I am hoping the foaming is not an issue.
I have ridden in much colder temps than that and never saw foam in my oil.
Do you not have any breather on the bike?
That will let condensation get into the crankcase.
- KZJOE900
- Admin
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
