HELP!! ISSUES!!!
- battleholic92
18 Dec 2012 14:48 #563534
by battleholic92
hair grease and sailor jerry tattoos
HELP!! ISSUES!!! was created by battleholic92
MY KZ400 IS RUNNING LIKE COMPLETE CRAP! SOME TIPS WOULD BE GREATLY APPRECIATED!
- mwriders
- if I only had a brain
- Thank you received: 6
18 Dec 2012 15:08 #563538
by mwriders
1980 Kawasaki KZ440B (brand new eBaby)
1998 Ducati 900S (gone)
1978 BMW R100S (gone, damn it)
1975 Yamaha RD350 cafe (gone)
1986 Yamaha XJ650 Seca (gone)
1981 Kawasaki KZ440LTD (gone)
1969 HD Sportster (gone
1966 Honda CB160 (gone, damn it)
1965 Suzuki 80
Replied by mwriders on topic HELP!! ISSUES!!!
Sounds like the choke is closed.
1965 Suzuki 80
- mick z1a
- Thank you received: 11
18 Dec 2012 15:25 #563542
by mick z1a
Replied by mick z1a on topic HELP!! ISSUES!!!
have you tried adjusting the idle screw?
- battleholic92
18 Dec 2012 16:03 #563546
by battleholic92
Replied by battleholic92 on topic HELP!! ISSUES!!!
choke is closed. bike turns off when choke is open, it runs at 1k when cold but run at 3-4k after it warms up?
- mwriders
18 Dec 2012 16:29 #563550
by mwriders
1965 Suzuki 80
This was a running bike before this issue?
1965 Suzuki 80
- MFolks
- Thank you received: 540
18 Dec 2012 16:33 #563551
by MFolks
Replied by MFolks on topic HELP!! ISSUES!!!
Check for a vacuum leak,some of the spray carb cleaners have had the formulation changed by EPA mandate, but read this method of vacuum testing:
(Using An UNLIT Propane Torch For Vacuum Leaks)
Use a fresh set of sparkplugs, and check the input voltage of the ignition coils too.
Testing Kawasaki Ignition Coils For Input Voltage
When voltage testing Kawasaki Ignition Coils, the following needs to be done:
1. Remove the fuel/gas tank to access the coils.
2. Fully charge the battery.
3. Using a multimeter, set it up for VDC(Volts, Direct Current), range of 20.
4. Turn on the ignition switch and the run/stop switch to “Run”.
5. Put the multimeter’s RED probe on where the red or red/yellow wire goes on the ignition coil.
6. Put the multimeter’s BLACK probe on either the battery Negative(-) post/terminal or a good frame ground.
7. You should be able to see battery voltage at the ignition coil connection, but this depends on the current draw of other items in the same circuit.
8. If the tested voltage is down to 8-9 volts, you probably need to clean the many and various electrical connectors.
9. To check the spark output at the sparkplugs, use these:
Ignition Spark Testers
www.lislecorp.com/divisions/products/?pr...ivision=1&category=8
(Using the Thexton 404 Spark tester)
Instead of grounding the sparkplug with the sparkplug wire attached, looking for a spark. This method puts the IC Igniter and ignition coils at risk of failure due to high currents, and possible internal shorting.
The sparkplug caps contain a non serviceable 5000 ohm resistor, that can fail due to age,heat & vibration. Tese can be checked using a multimeter, after they are unscrewed from the sparklug wires.
- battleholic92
18 Dec 2012 18:34 #563565
by battleholic92
the bike was running and i would idle right, im thinking it might be dirty carbs?
