what pistion should i use z900 z1000j head 8-1 com
- brassballs
17 Dec 2012 01:40 #563332
by brassballs
what pistion should i use z900 z1000j head 8-1 com was created by brassballs
i hope some one can help..new motor kawasaki z1000 1976 73mm wiseco pistion with z1000 j head.the motor has been cc'ed ond only has 8-1 comp. .what piston do i need to run this going into a race bike
- lushbaugh
- everybodys a pro......
- Thank you received: 35
17 Dec 2012 01:45 #563333
by lushbaugh
79 kz1000 ltd all apart
the best advice i can give is dont take dnthavakawmans advice..
Replied by lushbaugh on topic what pistion should i use z900 z1000j head 8-1 com
73 mm is 1105, i think they only made those pistons in 10.25 to 1 your compression is low due to the j head swap. you can get custom pistons made, deck it to bring it back up, or use a kz head. thats the only things i can think of.
- 4TheKZ1000
- Visitor
17 Dec 2012 01:45 - 17 Dec 2012 01:46 #563334
by 4TheKZ1000
Replied by 4TheKZ1000 on topic what pistion should i use z900 z1000j head 8-1 com
thats a turbo comp
stock is about 8.7 - 1
race can start at 10 and go though 13 to 1
Last edit: 17 Dec 2012 01:46 by 4TheKZ1000.
- wireman
- Thank you received: 299
17 Dec 2012 02:07 #563335
by wireman
Replied by wireman on topic what pistion should i use z900 z1000j head 8-1 com
You could check with ape to see if they stock an 1105 kit for j-series motor,they don't list one on the website but Im sure they don't list every combination they can get.
Or you could just call mr turbo and get it over with! :woohoo:
- brassballs
17 Dec 2012 03:12 #563338
by brassballs
Replied by brassballs on topic 1105 hi comp pistons z1000-with j head
i have z1000 with 1105-73mm pistons,and have fitted a z1000j head,the comp has gone to 8-1.i have seen this done before,i am at a loss as to what pistons i can get to up the comp.i have tipped $$$ into the head as it is to go on my race bike and i dont want to not use it..can any one help with info ,cheers
- taildragger1197
- Thank you received: 17
17 Dec 2012 04:32 - 17 Dec 2012 05:36 #563340
by taildragger1197
Union City, Tennessee
1979 KZ1000 LTD B3
1979 KZ1000(1260)LTD S/G Pro ET
1993 ZX11 D1 Ninja
Replied by taildragger1197 on topic what pistion should i use z900 z1000j head 8-1 com
You're going to need J model pistons with a spacer under your block. Make sure you measure your deck height and leave plenty of "squish". It is also very important to check valve to piston clearance if you're using a race only cam.
I installed a J-head with stage 1 porting on my 1260 KZ bottom end using this combination and it was the biggest improvement I ever made to my bracket bike. A real kick in the pants.
I would give APE a call. They have everything you need.
More info here
More info here
1979 KZ1000 LTD B3
1993 ZX11 D1 Ninja
Last edit: 17 Dec 2012 05:36 by taildragger1197.
- lushbaugh
17 Dec 2012 13:35 #563372
by lushbaugh
just go turbo lol, internally your done, stock j cams are great for boost
- gpz1170
- Thank you received: 10
17 Dec 2012 15:37 #563385
by gpz1170
1974 Z1
1976 KZ900
1978 KZ1000
1981 KZ1000
1983 GPZ1100
Replied by gpz1170 on topic what pistion should i use z900 z1000j head 8-1 com
MTC Wiesco or any piston manufurer make pistons for using a KZ bottom end with a J cylinder head. The wrist pin hole is moved to allow for the extra KZ rod length. Call the manufacturer of choice.
don
don
1974 Z1
1976 KZ900
1978 KZ1000
1981 KZ1000
1983 GPZ1100
- APE Jay
- Banned
- Thank you received: 58
17 Dec 2012 22:42 - 17 Dec 2012 22:43 #563446
by APE Jay
Replied by APE Jay on topic what pistion should i use z900 z1000j head 8-1 com
There is no off the shelf piston for this application. Besy way is to run a J piston and a .040" spacer.
73mm is not available. 72 and 74 are.
If the OPs block is a KZ1000 with the oem sleeves bored to 73mm, it is a poor choice for a race motor. Put some bigger sleeves in it and run 74 or 75 mm J pistons.
Last edit: 17 Dec 2012 22:43 by APE Jay.
- wireman
17 Dec 2012 23:09 #563449
by wireman
:laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh:
