- Thank you received: 13
suspected leaky manifolds.
- Roadflyer
So, am I better off to just buy new manifolds or try to seal up the existing ones?
Thanks.
Don
1979 kz1000 shaftie rebuild project
1045 wiseco 10.25-1 pistons
Kenny Harmon 380 lift cams
- peter1958
- Banned
- Thank you received: 198
- Roadflyer
peter1958 wrote: spark plug caps might be bad also tighten main ground wire. Hope this helps
The ground connection is clean and tight, the coils, wires and caps are all brand new.
Thank you for the thoughts.
- peter1958
- Banned
- Thank you received: 2829
- Roadflyer
650ed wrote: If the carb holders are leaking they really should be replaced. Try this (if possible) - warm the engine up so it is fully up to normal operating temperature. Temporarily set the idle as low as possible (under 1k rpm). Spray carb cleaner around the mating surfaces between the cylinder head and carb holders and around the joint where the carbs attach to the carb holders. If the idle changes (engine may stop running) you have a leaky carb holder. Keep in mind that for this test the lower the idle the better because that causes more vacuum to be applied to the carb holders since the engine cannot suck much air past the slides. If they are leaking it is much better to replace them than to try to seal them up. I ran this test and found mine were leaking badly even though they looked great from the outside. They had very fine cracks on the mating surfaces (nearly invisible to the naked eye), and when I ran the test the engine stopped running. I replaced them (this was 8 years ago) and I really could not believe the improvement in the idle. I've had no idle problems since. Ed
Yeah.... I should just order up some new ones. Its too cold and windy to test them outside and I can't be running the bike and spraying carb cleaner inside my shop.
Thanks.
Don
- MFolks
- Thank you received: 540
(Using An UNLIT Propane Torch For Vacuum Leaks)
- Thank you received: 2098
