- Thank you received: 3
TANK TALK
- gixxerkidd03
14 Dec 2012 21:27 #563004
by gixxerkidd03
1981 KZ750e
TANK TALK was created by gixxerkidd03
heres my question, i have a 82 750h frame with a 750e engine ( not that it matters). i noticed that the 750E fuel tank has a little different tank then the 750H. and i really want the 750E tank. will i run into and issues? the rear mounting point looks the same. i just like the little squared look in the rear oppose to the tear drop crusier look on the 750H. please tell me that it will fit!
1981 KZ750e
- gixxerkidd03
14 Dec 2012 23:31 #563022
by gixxerkidd03
- wireman
- Thank you received: 299
14 Dec 2012 23:44 #563023
by wireman
Replied by wireman on topic TANK TALK
I just checked my usual source of info and they didn't have a picture of tank or frame for either model
you might just have to buy a tank and start modifying brackets and seat.........
- wireman
15 Dec 2012 00:02 - 15 Dec 2012 00:09 #563024
by wireman
Heres what I could find in the 750 gallery
Attachment 750e.jpg not found
Last edit: 15 Dec 2012 00:09 by wireman.
- gixxerkidd03
15 Dec 2012 06:01 #563062
by gixxerkidd03
1981 KZ750e
Replied by gixxerkidd03 on topic TANK TALK
well thanks.. ill just buy it and see what i can do with it. i just wish someone knew
1981 KZ750e
- Thank you received: 1656
15 Dec 2012 16:52 - 15 Dec 2012 18:30 #563097
by martin_csr
Replied by martin_csr on topic TANK TALK
At least on person on this forum reported that the 750E tank will bolt-on to the H frame, BUT the upper triple will bang against the tank. If you look at some ebbaayy pics, you can see that the E triple is kinda angled forward, whereas the H is kinda straight across... which is probably why the H triple contacts the tank. I've checked into this as I've been interested in getting a larger tank. My bike has the same frame as the 750H.
Last edit: 15 Dec 2012 18:30 by martin_csr.
- gixxerkidd03
22 Dec 2012 19:22 #564121
by gixxerkidd03
1981 KZ750e
so i recieved my new tank today. i went ahead and ordered the 750e tank. this thing is big! i never had a reference on the size difference. my only issue as of now is it contacts some brackets i welded on to level the seat section. ill post some photos to you guys can check it out and tell me what you think
1981 KZ750e
- gixxerkidd03
22 Dec 2012 19:35 #564126
by gixxerkidd03
- gixxerkidd03
22 Dec 2012 19:39 #564127
by gixxerkidd03
1981 KZ750e
with the way the new tank looks i almost just want to put a bench seat on it.
1981 KZ750e
- peter1958
- Banned
- Thank you received: 198
22 Dec 2012 19:42 #564128
by peter1958
Replied by peter1958 on topic TANK TALK
looks great if you can fix where it hits. Nice lines!!
- wireman
22 Dec 2012 20:02 #564132
by wireman
Attachment quag_2012-12-22.jpg not found
- gixxerkidd03
22 Dec 2012 21:51 #564157
by gixxerkidd03
1981 KZ750e
oh and i dont have any contact with my triples. the bike started off as a 78 650 with a 750 motor from an 82. the bike had no title so a bought a titled frame and did it that way. well i wasnt thinking and when i had everything powder coated the only triples i had where from the old 78 650. which i didnt figure out was a big deal until i tried to mount my mag wheel from the 82. so for now ill be running the front spoke and rear mag.
1981 KZ750e
