- Thank you received: 2
"While you're in there" jobs? - GPZ1100 bottom end
- moorepower
13 Dec 2012 20:39 #562860
by moorepower
'81 GPZ1100 mutt, coming out of 10 year hibernation
"While you're in there" jobs? - GPZ1100 bottom end was created by moorepower
Hello all, this is my first post, so be gentle.
I'm fixin' to tear into the crankcase of my '81 GPZ1100, and I was wondering if there were any usual problem areas that I should pay close attention to, or any parts that I should plan on replacing whether they need it or not.
This was a good-running, low mileage engine about ten years ago when I parked it ( :blush: ), but it's been sitting in my shed with the top end removed for about the last year or so. I plan on replacing all the gaskets and seals, cleaning out all the dirt and varmints that may be in there, and generally checking everything over.
I was also thinking of sending the crank out to be trued and welded, and maybe putting in some APE main studs. Is this necessary for a street bike? Anything else I'm missing?
Any input is appreciated.
- Thank you received: 2064
13 Dec 2012 22:58 #562884
by Street Fighter LTD
Replied by Street Fighter LTD on topic "While you're in there" jobs? - GPZ1100 bottom end
Welcome Moorepower :laugh:
Cam Drive chain for sure, (Just because ).
Top end and lower end studs are nice ( I have them ) but not a mandatory
Weld and check the crank as mentioned
Question
What motor upgrades if any are you planning
This would help us all guide you thru what is needed vs what is nice
AND Where are the pictures !!!
Question
- wireman
- Thank you received: 299
14 Dec 2012 00:11 #562888
by wireman
Replied by wireman on topic "While you're in there" jobs? - GPZ1100 bottom end
Save your money and don't worry about main studs,spend your money on anything worn/questionable while youre in there.
Definitely check out the crank
- moorepower
14 Dec 2012 01:04 #562898
by moorepower
Here's a couple of pics from when it was more or less all together. Sadly, I've sold the exhaust, fork brace, and cylinder head since these were taken.
Replied by moorepower on topic "While you're in there" jobs? - GPZ1100 bottom end
Eventually I'm planning a Wiseco 1170 kit, some mild cams, V&H header, and an as-yet undetermined carb upgrade. I'm looking for good mid-range power, not so much peak hp. I'm getting too old for that.Street Fighter LTD wrote: Question
- Motor Head
- Thank you received: 391
14 Dec 2012 02:05 #562921
by Motor Head
Replied by Motor Head on topic "While you're in there" jobs? - GPZ1100 bottom end
Have you got the factory manual for the bike? It will have all the info needed to inspect the engine/ trans/ clutch.
The manual in my signature will have most info for your engine, a pdf file download. Adobe Reader or another pdf reader is required.
Along with the gaskets and seals, an up grade of the valve stem oil seals is a good idea. Teflon seals are available.
