- Thank you received: 35
head removal...
- lushbaugh
- everybodys a pro......
79 kz1000 ltd all apart
the best advice i can give is dont take dnthavakawmans advice..
- KZJOE900
- Admin
lushbaugh wrote: pulling the top end off to see what im doing for the bore and crank for the turbo build and i cant get it off, all the nuts and two ten mm bolts are out, hit it with a rubber mallet like it owed me money and all.... any tips?
Yes, be very careful you don't break any fins or warp the head. Here is how I got mine off:
When taking the cylinder block off. Only use a large blade screw driver in the bottom slots as a last resort. And if you do don't hammer it and don't put too much pressure on it. Otherwise, you may damage the block and or the slot expands and you may damage the gasket surface contact area. Good luck.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
- 893cv
- Thank you received: 15
1980 kz1000 LTD
1978 Z1R
- wireman
- Thank you received: 299
I hear the French had decent luck with this,just check the alignment really good! :woohoo:
Attachment headremovaltool.jpg not found
- APE Jay
- Banned
- Thank you received: 58
- 4TheKZ1000
- Visitor
893cv wrote: Remove the plugs and with #1 at BDC stuff rope into cylinder (I use some soft clothes line rope)untill full and then turn the crank. This works every time and will not break any fins
This is interesting…never thought about it….but seems like a good solution….
- lushbaugh
- roy-b-boy-b
- Thank you received: 103
