Can't get into second gear
- X_Saint
12 Dec 2012 00:07 #562579
by X_Saint
Can't get into second gear was created by X_Saint
I have an 82 kz750 and when it's parked and the key is in the ignition I can put the bile into first and neutral but not second. I'm not sure if this is normal or not. If not I am wondering what could be the problem. Thanks
- 4TheKZ1000
- Visitor
12 Dec 2012 00:13 - 12 Dec 2012 00:16 #562581
by 4TheKZ1000
Replied by 4TheKZ1000 on topic Can't get into second gear
bike has to be running....nothing wrong with bike....kawasaki design it this way....
found this with a 2-second search.....???????????? :dry:
kzrider.com/forum/2-engine/3344-wont-shift-into-2nd
Last edit: 12 Dec 2012 00:16 by 4TheKZ1000.
- zukdave
- Thank you received: 229
12 Dec 2012 00:39 #562585
by zukdave
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
Replied by zukdave on topic Can't get into second gear
Bike has to be rolling to shift to second gear.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
