- Thank you received: 20
got the head off #1 piston stuck in the bore help!
- newOld_kz1000
- FlimFlamFlibbityFlee !! BoonFryedShickaMuhZee !!
Here's what I've tried so far:
1) penetrating oil bigtime on #1, dousing and dousing, liberally
2) put some household oil right in behind the Amazing Blaster
3) have whacked on the top center of the #1 piston using a big rubber mallet on a wood stake
4) put the bike in its top gear and rocked it, kicked it with kick starter, that dang #1 piston won't come free
I felt the #1 bore and it doesn't feel bad, and the bike had sat for years, and initially the other pistons were also stuck but they're free, it's only this #1 piston.
I am tempted to let the #1 piston and cylinder rise up off the crankcase, then lodge a wood block between the bottom of lifted-up cylinder and the cases, one piece of wood in front and one in back, then rotate the crank so it's not at TDC and whack that dang #1 piston like a stepchild.
Any other ideas?
1978 kz1000 A2 with Kerker
1980 Z1 Classic with Kerker
- 4TheKZ1000
- Visitor
This is a suggestion as it might not be a gr8 idea....lets see what others think first. If the jug is painted it would ruin it ???
- Thank you received: 2829
- etbike3135
- Thank you received: 50
1973 Kawasaki Z1
18 years in dragbikes
- kzz1king
- Thank you received: 52
Wayne
Home built KZ1000 turbo setup
- floivanus
- Thank you received: 116
Put shims under the jug put the plate on the cylinder add the nuts and crank the bolt slowly should break loose
Past; 78 kz1000, 83 kz550
Andrew
- wireman
- Thank you received: 299
- 4TheKZ1000
- Visitor
wireman wrote: Buy a gallon of acetone at the hardware store and dump it down that cylinder overnight ,then try working the cylinder loose
he said ass e tone ..... :woohoo:
he said dump..... :silly:
- newOld_kz1000
So I don't get how a steel plate on top of the cylinder is helping here.
How would I set this up? Again, with the cylinder setting flush on the cases, the #1 piston is stuck in my estimation at the lowest point. I don't see how to use the cylinder studs here for leverage. What am I missing here? And thanks for the tip, hope I can figure it out!
- wireman
- zukdave
- Thank you received: 229
should still be enough stud to bolt a plate to.
Make the plate so you can still get a torch inside
the cylinder and apply heat to the TOP liner not the piston.
As the heat runs down the liner it will expand and let go of the piston.
Worst case I did use an air chisel one time to get a GT750 cylinder off the studs
for the crank.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
- floivanus
Andrew
