trans cover oil seals
- pete greek1
07 Dec 2012 13:54
how much work is involved in replacing the oil seals on the trans cover on a 76 LTD 900, will i need any special tools ?...Pete
- StreetfighterKz
Re: trans cover oil seals
07 Dec 2012 14:44
The only special tool you may need is an impact gun to remove the countershaft sprocket nut. Everything else is straight forward. You will have to drain the oil, obviously.
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- MFolks
07 Dec 2012 15:21
While you're in there, replace the clutch rod and shifter shaft seal too.
- pete greek1
07 Dec 2012 16:16
Thanks, Doug, & MFolks for your quick replies...Pete
