- Thank you received: 27
Clutch Rebuild Time!!!
- havakaw
06 Dec 2012 18:58 #561752
by havakaw
'80 KZ 750 LTD-H
'82 KZ 1100 A-2 Shafty (ex-bagger)
Clutch Rebuild Time!!! was created by havakaw
So now that it's 25* in Western NY,I figure it's time to re-buld the clutch in my '82 KZ 1100 Shafty.I'm looking at kits that have the steels,fibers and springs.It looks like the only people who have them at "reasonable" prices are EBC and Barnett.I could go with either kit.Anybody have any experiance with either,or reccomend one or the other?Thanks.
'80 KZ 750 LTD-H
- lushbaugh
- everybodys a pro......
- Thank you received: 35
06 Dec 2012 19:01 #561754
by lushbaugh
79 kz1000 ltd all apart
the best advice i can give is dont take dnthavakawmans advice..
Replied by lushbaugh on topic Clutch Rebuild Time!!!
in a kz no but barnetts tend to be grabby when there hot. ebc is oem replacement grade. most barnetts have the heavier springs etc. some one correct me if im wrong but in my gsxr i had to get rid of the barnett and kept the heavy springs.
- RonKZ650
- Thank you received: 240
06 Dec 2012 19:08 #561756
by RonKZ650
Replied by RonKZ650 on topic Clutch Rebuild Time!!!
My opinion after using Barnett in the past is don't. You most likely can just replace the fiber plates with original Kawasaki parts, keep the steel plates and springs as they are. I can't imagine the springs or steel plates being bad. Heavier springs do no good other than giving your left wrist more exercise and cause unnecessary wear on the clutch cable and release mech.
- baldy110
- Thank you received: 512
06 Dec 2012 19:34 #561759
by baldy110
Replied by baldy110 on topic Clutch Rebuild Time!!!
If your steel plates are not warped then just replace the fiber sones with the stock EBC replacement and use the EBC heavy duty springs.
I just replaced the clutch on my modified GPz1100 with this setup and am very happy with it. Smooth engagment and easy pull on the lever. If you can find them at a reasonable price I would use the stock OEM fiber plates. I went with the EBC because the OEM plates were way to pricey for me. Do some research and you will find back in the day the superbikes used stock clutch plates with just heavier springs. The OEM plates are really good just pricey.
- Thank you received: 2829
06 Dec 2012 19:53 #561766
by 650ed
Replied by 650ed on topic Clutch Rebuild Time!!!
How much cheaper are the aftermarket pieces compared to stock (are they even cheaper at all)?
All the stock parts are still available; here are the prices at Ronayers.com
92081-1114 Spring, clutch; $2.77 each x 6 = $16.62
13088-1013 Plate, friction; $7.77 each x 9 = $69.93
13089-1004 Plate, clutch, steel; $7.59 each x 8 = $60.72
Total = $147.27
Total = $147.27
Attachment 00000_2012-12-06.jpg not found
- Thank you received: 2098
06 Dec 2012 20:14 #561773
by Patton
Replied by Patton on topic Clutch Rebuild Time!!!
Before replacing any clutch parts, should be certain that a proper clutch push rod adjustment has been performed.
