Torque spec for Cam Cain tensioner body?
- KZJOE900
- Admin
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
- Thank you received: 797
here is a cahrt unitl someon pops up with the real info.
imperialsupplies.com/pdf/A_FastenerTorqueCharts.pdf
- KZJOE900
- Admin
531blackbanshee wrote: sounds like too much torque to me.
Thanks Leon, I am concerned about it since I mounted it. I hope it holds but will keep an eye on it. Your chart seems more reasonable. If I do have to make are repair on it, how feasible is it to tap it out to an M8 instead of doing the helicoil? What is recommended? I figure tapping it I can do with it on the bike and only requires the carbs to be out space wise.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
- Thank you received: 2829
www.scribd.com/doc/48655900/Kawasaki-KZ-...B1-77-Service-Manual
- KZJOE900
- Admin
650ed wrote: 14.5 ft pounds is WAY too much; It is stripped. I think it's time for you to toss out the Clymers manual and buy a Kawasaki Service Manual. The KZ650 manual calls for 61-78 INCH pounds of torque on those bolts. That equals 5.1 - 6.5 FOOT pounds. See page 35 in link:
Thanks Ed. Yeah, that number seems more reasonable. Would like to replace these bolts with M8's. Not sure. Or maybe I can just re-tap (chase the thread) for the existing M6. Not sure what the best way to go. I will look for an FSM specific to my bike. Two manuals had kept me going until now. But after look at your FSM, I see that it would be worth while.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
- baldy110
- Thank you received: 512
