Motorcycle Oils
Re: Motorcycle Oils
04 Dec 2012 15:09
Brad Penn motor oil -- not cheap
This weird green oil is known for its ability to keep itself draped over an engine’s internal rotating assembly parts during the most crucial test for any oil: startup. Worst thing you can do for an engine, starting it up. There’s not enough oil flinging around between metal parts in the engine and there’s no pressure built up yet. So, there are a few moments on startup when oil really needs to be where it currently is not. This is where Brad Penn shines.
autoculture.org/?p=1065
- donthaveakawman
Re: Motorcycle Oils
04 Dec 2012 15:20
I just bought a 10$ liter of wet clutch protection oil. the quart at the auto parts store is usually 5.99 but the liter is slightly larger.
- OnkelB
Re: Motorcycle Oils
04 Dec 2012 15:33 - 04 Dec 2012 15:39Surfdude_007 wrote: ...Has anyone heard of Blendzall or Silkolene...
Never heard of Blendzall, but I've been running Silkolene Comp4 in both my bikes for the past 5 years or so, perfectly happy with it.
Before that I ran Motul 5100, pleased with that too but my local bike shop stopped carrying it.
Both oils are Jaso MA rated btw.
77 KZ 650 B1, 82 GPz 1100 B2.
Last edit: 04 Dec 2012 15:39 by OnkelB.
- donthaveakawman
Re: Motorcycle Oils
04 Dec 2012 16:52
valvoline works fine with some motorcycle lucas additive.
- bountyhunter
Re: Motorcycle Oils
04 Dec 2012 19:05 - 04 Dec 2012 19:07
I have yet to read a bad post on Rotella (dino or syn).
IMHO, just use a good quality oil and change it often. That will keep your engine a lot cleaner. FWIW, the base oil (dino or syn) almost never fails but the additives get broken down or used up hence my habit of changing often. MC's are inherently brutal on oil since their temps run pretty high compared to cars, the teeth in the gearbox also acts like a blender chopping on the additives.
I have always used car oils in mine (Castrol/ Valvoline etc), but you do have to make sure the top of the can does NOT say "energy conserving" because that will have the friction modifiers like moly which can screw up your clutch. If the oil used is service grade SL, SM or SN, it will not have enough ZDDP. You can buy it aftermarket and add it. I use ZDDPlus. STP oil treatment also has a good dose of ZDDP in it, but that will raise your oil viscosity about 4 points.
Last edit: 04 Dec 2012 19:07 by bountyhunter.
- Powerstroke_fan
Re: Motorcycle Oils
04 Dec 2012 19:36
I use Rotella T also. Its some good stuff.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- zukdave
Re: Motorcycle Oils
05 Dec 2012 00:03
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- bountyhunter
Re: Motorcycle Oils
05 Dec 2012 01:03 - 05 Dec 2012 01:06
I would NEVER run a single grade 30W oil. At cold start up, the viscosity is going to be way off what is needed to get optimum film on the bearing face. The factory manual on mine says 10-40 or 20-50 only.
Last edit: 05 Dec 2012 01:06 by bountyhunter.
- donthaveakawman
- bountyhunter
Re: Motorcycle Oils
05 Dec 2012 18:33good eye, I didn't even see that. :laugh:donthaveakawman wrote: if you read the small print, that is for lawnmowers.
- zukdave
Re: Motorcycle Oils
05 Dec 2012 23:19donthaveakawman wrote: if you read the small print, that is for lawnmowers.
I wouldn't run the 30 wt in my bike thats why
I'm seeing if we can get it 10w40.
We use the 30wt in the mowers at work but the oil is JASO MA spec.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- donthaveakawman
Re: Motorcycle Oils
05 Dec 2012 23:28
What about Torco oil, must be good I paid 10 USA dollars for a liter.
