Weak Starter, or ???
- PaulyWally
- Total Bike Newbie
What happens: I press the start button, the starter motor engages, but it only turns the engine once every couple seconds. I briefly connected my car battery to it to make sure it wasn't the battery, and it does the same thing. FYI: Kickstarter acts normal. Here's a video:
1976 KZ750 Twin
- Thank you received: 2829
- PaulyWally
- Total Bike Newbie
Sounds like it's time to rebuild the starter clutch. The starter itself is probably fine. Ed
That was the last of the repairs I went through this past year. I just finished rebuilding the starter clutch a couple weeks ago. I reused some parts and replaced others with new parts, NOS, and used. Before I closed up the bike, I ran the starter (briefly) just to witness the clutch engaging properly. It was - no slipping.
So, obviosly I can't be 100% positive at this point, but I "believe" that the starter clutch is not slipping. It catches, but just won't turn the engine easily.
1976 KZ750 Twin
- wireman
- Thank you received: 299
- wireman
Did you torque the bolt on end of crank?
[attachment:1]C:\fakepath\Image.gif[/attachment]
- PaulyWally
- Total Bike Newbie
wireman wrote: Did you torque the bolt on end of crank?
I did. To 55ft-lbs (according to the service manual).
1976 KZ750 Twin
- KZ_900_Z1
1976 kawasaki kz900
- baldy110
- Thank you received: 512
- Thank you received: 2098
KZ_900_Z1 wrote: i kinda got the same problem with my 76 kz900, but the key inside my starter keep breaking anyone know how i can fix it this will be the twelth key i have went through
Click here > www.kzrider.com/forum/4-electrical/56135...eeps-breaking#561350
- Del_Herring
1983 KZ750-N2 Spectre
- PaulyWally
- Total Bike Newbie
If I take this thing apart again, what exactly do I need to be looking for? Because to my unexperienced eyes, it all looked to be working properly before I put the stator cover back on.
1976 KZ750 Twin
- baldy110
Check the surface the rollers ride on, the rollers themselves and their springs. Make sure none of these items are pitted or show any signs of wear. If the starter gear shows any cupping or wear replace it. Also if you have not done so replace the roller springs with new ones not used even they are within specs.
