WHICH ENGINE SHOULD I BUILD?
- 1984=KZ750-L4
02 Dec 2012 06:57 #560909
by 1984=KZ750-L4
WHICH ENGINE SHOULD I BUILD? was created by 1984=KZ750-L4
NEED SOME ADVIVE ON WHICH BIKE I SHOULD RESTORE...
BIKE #1
84 KZ 750, L4
Bike is complete, runs, but leaks so much oil you need new pants every ride, clutch and trans feel great, engine very noisy and rattles, over all condition is 4 out of 10
BIKE #2
82 GPz 750R
Bike is complete and in better condition looks wise, 6 1/2 out of 10.
But the case has a hole in the side from probally a rod,
this bike came wit h a motor that is supposed to run 83 GPZ motor.
this was my thinking......take the 83 motor and but it as is into bike number one, to resell.... then take the cylinders and heads from the broken case motor and
and but them on the kz lower end, and while apart build a 810....
any comments or advice is appreciated... thanks
BIKE #1
84 KZ 750, L4
BIKE #2
82 GPz 750R
- steell
02 Dec 2012 13:34 #560957
by steell
Replied by steell on topic WHICH ENGINE SHOULD I BUILD?
If the rod put a hole in the case then it's very likely to have damaged the cylinder and head.
- zukdave
- Thank you received: 229
02 Dec 2012 13:45 #560962
by zukdave
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
Replied by zukdave on topic WHICH ENGINE SHOULD I BUILD?
Put the Gpz motor in the 82 Gpz
and sell the rest.
and sell the rest.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- 1984=KZ750-L4
02 Dec 2012 13:49 #560964
by 1984=KZ750-L4
Replied by 1984=KZ750-L4 on topic WHICH ENGINE SHOULD I BUILD?
SHOULD I JUST STRIP THE Broken case motor and have it checked out piece by piece... there is a very small hole in the case right beside the right motor mount, thumb size
