83 gpz 750
- souljur412
- ramtough_63
souljur412 wrote: when idling i hear a slight rattle on left side lower end ...anything to worry about or is it normal
sure its not on the right lol mine does same thing someone told me was clutch basket but i
started parting it out so i never fixed it
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
and various enduros dirtbikes minibikes...
- RTGPZ
- Thank you received: 7
old school w/ new look
02gsxr 1000 front forks w/6 piston calipers
06 gxsr 750 rear suspension
6 speed trans out of gpz550
Reinforced frame
- steell
Get your carbs out of sync, then say thatRTGPZ wrote: I would say dig a lil deeper ,but my 83 gpz doesn't rattle
Rattle on the lower left side is usually the primary chain (inside the motor), if it only does it at idle then it's almost certainly the primary. Sync your carbs and it should go away.
Nothing to worry about either way, and there is no adjustment.
Welcome to KZR :lol:
- RTGPZ
Reinforced frame
- Bozo
- Ride it like u stole it
- Thank you received: 105
- steell
RTGPZ wrote: it s hard to diagnos noises 1200 miles away, if you could look a lil closer to let people help figure out your problem .it could be an exhaust clamp or a broken exhaust pipe or a valve out of adjustment or a starter cover rattle or any number of things ,help us help you. For those of us that aren't jedi knights in the ways of the force
- steell
Bozo wrote: Kind of reminds me of a commercial (supercheap auto) we had in Australia where a guy has a rattle in the dash of his car. Goes out and buys a full set of tools and starts ripping the dash apart, then he goes to remove the ash tray and finds a set of (looks like) bolts rattling away.
Does it remind you of the 100's of times this question has been asked on this board over the years?
Probably the second most asked question, after "why won't my bike shift into second when it's parked or not running".
- zukdave
- Thank you received: 229
at the drag strip Friday night.
Throught I'd trashed my motor.
Turned out the glass in the left bar end mirror came loose
and was vibrating bad.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
