oil pressure check
- souljur412
01 Dec 2012 14:58 #560796
by souljur412
oil pressure check was created by souljur412
just bought a used 83 gpz750 hasnt been on road for years...12k miles is a oil pressre check critical and if so do i have to use the kawasaki oil pressure gauge or will aftermarket do? thankz
- baldy110
- Thank you received: 512
01 Dec 2012 20:27 #560839
by baldy110
Replied by baldy110 on topic oil pressure check
No, if the oil pressure light goes out then your fine.
- 4TheKZ1000
- Visitor
01 Dec 2012 20:45 - 08 May 2013 00:25 #560841
by 4TheKZ1000
Replied by 4TheKZ1000 on topic oil pressure check
No eBay APP ID and/or Cert ID defined in Kunena configurationI put a gauge on mine....it works great.
Attachment not found
Last edit: 08 May 2013 00:25 by 4TheKZ1000.
- Thank you received: 2829
01 Dec 2012 21:11 #560851
by 650ed
+1
Replied by 650ed on topic oil pressure check
baldy110 wrote: No, if the oil pressure light goes out then your fine.
+1
- RTGPZ
- Thank you received: 7
01 Dec 2012 21:23 #560854
by RTGPZ
old school w/ new look
02gsxr 1000 front forks w/6 piston calipers
06 gxsr 750 rear suspension
6 speed trans out of gpz550
Reinforced frame
Replied by RTGPZ on topic oil pressure check
Plain bearing motor s like the gpz hold higher pressure then roller bearing, so an aftermarket pressure guage will work as long as you find a place to put it. Under the right side crank cover bottem of case is a plug also right below cover there s a nut to check oil pressure on the outside of case. You probably know this, just trying to give info
Reinforced frame
