'82 KZ550 LTD Exhaust options.
  • JDShapp21
  • JDShapp21's Avatar Topic Author
01 Dec 2012 06:33
#560769
I'll start with a little background first. I bought this '82 KZ550 LTD not long ago for $300. I'm already in the process for fixing its wiring problems, but so far it appears to be mechanically sound. The person that had it before was intending to turn it into a bobber. That being said the original exhaust was either bad or he decided it wasn't needed. Eitherway the exhaust pipes were cut around at the joint on the 2 to 1 on either side of the bike.
Personally the noise wouldn't bother me, but I can't run straight pipes here and I know that this isn't a good idea without doing adjustments. So for now I'm looking for peoples suggestions. I currently have a '78 KZ650 C2 thats a project, and it happens to have a Kerker System K exhaust on it. Is there anyway to repurpose the 650's exhaust for the 550? If not then I'm open to suggestions on a good aftermarket exhaust just in case I strike out on finding anything useable at the local motorcycle salvage place?
1982 KZ550 LTD C3
1978 KZ650 C2
  • martin_csr
  • martin_csr's Avatar
Re: '82 KZ550 LTD Exhaust options.
01 Dec 2012 17:01 - 23 Jan 2013 12:45
#560817
If your headers are fine, you might be able to use Dunstall replica mufflers from some of the on-line places, such as JC Whitney or J&P Cycles, etc. Here's a photo of verner-650's bike w a set.
Last edit: 23 Jan 2013 12:45 by martin_csr.
