Starter clutch
- stcyreeve
30 Nov 2012 18:14 #560689
by stcyreeve
Starter clutch was created by stcyreeve
I need to know if the starter clutch assembly from a 1983 KZ750F will work in my 1980 KZ750E. both are 4 cylinders.
- steell
30 Nov 2012 19:06 #560694
by steell
The following user(s) said Thank You: stcyreeve
- Thank you received: 2829
30 Nov 2012 19:06 - 30 Nov 2012 19:08 #560695
by 650ed
Replied by 650ed on topic Starter clutch
According to Kawasaki.com - Yes. Are you planning to put used starter clutch parts in your bike? If so, it seems like a lot of work not to use new parts. Ed
Last edit: 30 Nov 2012 19:08 by 650ed.
- stcyreeve
30 Nov 2012 21:11 #560710
by stcyreeve
Replied by stcyreeve on topic Starter clutch
I live on disability and therefore have very limited funds. If I could afford new parts I would. Unfortunately I can only afford used parts. I always inspect them very carefully before installing them. Thanks for your help.
