oil drain bolt
- souljur412
30 Nov 2012 11:07 #560625
by souljur412
oil drain bolt was created by souljur412
Hey guy's is there supposed to be a washer on my 83 gpz750 oil drain bolt and if so what kind...material that is..... thankz souljur
- Thank you received: 1656
30 Nov 2012 11:18 #560629
by martin_csr
Replied by martin_csr on topic oil drain bolt
The diagrams at Kawasaki.com show a gasket; it is probably aluminum.
- Thank you received: 2829
30 Nov 2012 16:15 #560671
by 650ed
Replied by 650ed on topic oil drain bolt
Kawasaki.com says it's part number 92065-097. That's the same as the one used on the KZ650's, so it is aluminum as martin stated. It is still "Active" so any dealer can get it from Kawasaki if they don't stock it. Ronayers.com lists it at a whopping 29 cents each. Ed
Attachment 00000_2012-11-30-2.jpg not found
