73 z1 tranny issue
- BadAssRX7
29 Nov 2012 18:51 #560518
by BadAssRX7
73 z1 tranny issue was created by BadAssRX7
so i get a cal from the guy aross the street from me today. He said his 73 z1 wouldnt change into 3 2 or 1 gears but will change from 4 to 5 and back. He has had no issues in the past with the tranny. he says that theres no pressure or resistance like normal when bellow 4th gear or as he said "its like air" meaning no back pressure im guessing. Do the 1 pc head gasket motors have a tranny issue? any input would be great. thanks
- Kidkawie
- I bleed premix
- Thank you received: 245
29 Nov 2012 19:38 #560529
by Kidkawie
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
Replied by Kidkawie on topic 73 z1 tranny issue
Pull the trans cover off and look at the shifter.
1975 Z1 900
2004 KX125
- Thank you received: 2098
29 Nov 2012 20:52 - 29 Nov 2012 20:55 #560540
by Patton
Replied by Patton on topic 73 z1 tranny issue
Perhaps the shift lever is slipping on the shaft due to stripped splines or being insufficiently tightened onto the shaft. Or possibly using an improperly fitted shift lever from some other model.
Last edit: 29 Nov 2012 20:55 by Patton.
- ironpan65
- *UNTOLD*
29 Nov 2012 22:12 #560555
by ironpan65
UNTOLD
Replied by ironpan65 on topic 73 z1 tranny issue
I have interest in any known issues regarding the 73' trans also....
Low mileage 73' 900...needs to be wound up high RPM's and kicked up hard to shift up 3-4-5th
Clutch adjusted as per the book...
My 76' 900 shifts smooth...and shifts up without the clutch at the right RPM
I have dropped 2 shift forks out from the bottom and they appear to be straight and not worn...Could be wrong though :huh:
UNTOLD
- Kidkawie
- I bleed premix
30 Nov 2012 11:43 #560638
by Kidkawie
1975 Z1 900
2004 KX125
Pull the clutch and lightly sand the steel plates.
1975 Z1 900
2004 KX125
- Garn
- Thank you received: 13
01 Dec 2012 01:16 #560744
by Garn
1 x 73 Z1 (Jaffa), 74 Z1A, 76 Z900-A4
1 x 73 Yamaha TX500 & 98 fzx250 Zeal
Sydney Australia
Replied by Garn on topic 73 z1 tranny issue
Hate to mention it, however, on these 73 Z1's I have seen the boss that holds the shift mechanism spring broken. Major job, however worth a check by removing the front sprocket and inner cover. Hope it's not this!
If its gear wear it will require the crank-cases split. The trouble will probably be on the lay-shaft ... rounded pegs and rounded edges on slots. Wont let it hold second gear.
I hate being the voice of doom & gloom!
Somebody else may come up with something nice and easy.
RegardZ.
RegardZ.
Sydney Australia
