Width of collector / ODD KERKER FOUND??
  • 4TheKZ1000
  • Topic Author
  • Visitor
29 Nov 2012 00:55 - 30 Nov 2012 15:23 #560416 by 4TheKZ1000
Width of collector / ODD KERKER FOUND?? was created by 4TheKZ1000
I would love to ditch the sidewinder for a kerker.
where the 4 pipes go into the collector under the oil pan....could you please tell me what the greatest width of the pipe is.....in relation to ground clearance....
thanks
Last edit: 30 Nov 2012 15:23 by 4TheKZ1000.
29 Nov 2012 11:11 #560449 by 531blackbanshee
Replied by 531blackbanshee on topic Width of collector on Kerker
width or height?
  • mark1122
  • Keep twisting it
29 Nov 2012 11:26 - 29 Nov 2012 11:34 #560453 by mark1122
Replied by mark1122 on topic Width of collector on Kerker
i'm not sure i understand the question. but the Kerker has a 2 1/2" OD collector.
kzrider.com/forum/2-engine/271747-header-pics?limit=20&start=40
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 29 Nov 2012 11:34 by mark1122.
29 Nov 2012 11:32 - 29 Nov 2012 11:39 #560455 by Mcdroid
Replied by Mcdroid on topic Width of collector on Kerker
If you are talking of clearance of the collector, the double-stacked exhaust pipes of a Kerker system won't fit under your motorcycle (as pictured in your avatar) w/out hitting the ground at every bump in the road. I haven't met a Kerker yet that didn't have dents just anterior to the collector with a normally sprung motorcycle...yours is considerably lowered.
To answer your question (I think), the double-stacked exhaust pipes at the collector are about 2 3/4" thick...the pipes are mounted within 1/4" of the bottom of the motor.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Last edit: 29 Nov 2012 11:39 by Mcdroid.
  • mark1122
  • Keep twisting it
29 Nov 2012 11:35 #560457 by mark1122
Mcdroid wrote: If you are talking of clearance of the collector, the double-stacked exhaust pipes of a Kerker system won't fit under your motorcycle (as pictured in your avatar) w/out hitting the ground at every bump in the road. I haven't met a Kerker yet that didn't have dents just anterior to the collector with a normally sprung motorcycle...yours is considerably lowered.
X2 :(
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • 4TheKZ1000
  • Topic Author
  • Visitor
29 Nov 2012 11:49 #560458 by 4TheKZ1000
Replied by 4TheKZ1000 on topic Width of collector on Kerker
Yes...all thoughts to the bike and stance are correct. Thanks for OD of collector.
29 Nov 2012 13:02 - 29 Nov 2012 13:04 #560469 by 531blackbanshee
marving has a 4 into one that has the collector with the head pipes side by side instead of stacked.
kinda like the four flat on this page.
www.coneeng.com/collectors.html
if you wanted to build it or have it built for you.
i think it would be cool to use the four flat collector then use a kerker meg and a custom mid-pipe to connect them,use some dual exhaust head pipes and voila :cheer: .
Last edit: 29 Nov 2012 13:04 by 531blackbanshee.
The following user(s) said Thank You: 4TheKZ1000
  • 4TheKZ1000
  • Topic Author
  • Visitor
29 Nov 2012 18:39 #560513 by 4TheKZ1000
Never seen a quick release kerker before....any ideas on this one....whats it worth?
Attachment 3Ic3F63M65Id5F75J8cb476e463005a0a1f4e432x207.jpg not found
29 Nov 2012 18:43 #560515 by 531blackbanshee
hard to tell the condition from the pic.
what is it like dents/rust etc ?
  • 4TheKZ1000
  • Topic Author
  • Visitor
29 Nov 2012 18:45 - 29 Nov 2012 18:47 #560517 by 4TheKZ1000
531blackbanshee wrote: hard to tell the condition from the pic.
the guy said its good no dents...minor scrapes on collector....orig finish....minor rust..all parts there
Last edit: 29 Nov 2012 18:47 by 4TheKZ1000.
  • 4TheKZ1000
  • Topic Author
  • Visitor
29 Nov 2012 22:00 - 29 Nov 2012 22:04 #560553 by 4TheKZ1000
Replied by 4TheKZ1000 on topic Width of collector / ODD KERKER FOUND
Any ideas guys to what it is....if its rare and what its worth??
Attachment 3F43m93H55Kd5F25M3cb44144f10ef2221db7.jpg not found
Last edit: 29 Nov 2012 22:04 by 4TheKZ1000.
29 Nov 2012 22:08 #560554 by gengomerpyle
Replied by gengomerpyle on topic Width of collector on Kerker
ive seen pictures of them before, maybe a racing pipe.
4TheKZ1000 wrote: Never seen a quick release kerker before....any ideas on this one....whats it worth?
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
