- Thank you received: 2
stock compression ratio
- cjcrug
79 KZ 1000 B3 LTD
Wiseco 1105
Kerker 4 into 1
Dyna s ignition
Dyna green coils
K and n pods
Andrews 2x cams
- 4TheKZ1000
- Visitor
Type 4 stroke, DOHC, 4 cylinder, air cooled
Bore and stroke 70.0 mm x 66.0 mm
Displacement 1,015 cc
Compression ratio 8.7
Maximum horsepower 93 hp (69 kW) @ 8,000 rpm [93hp='79 Kz1000 E-1 shaft]
Maximum torque 8.1 kg-m @ 6,500 rpm
Valve timing
Open 30° BTDC
Inlet Closed 70° ABDC
Duration 280°
Open 70° BBDC
Exhaust Closed 30° ATDC
Duration 280°
Carburetors (4) Mikuni VM26SS or VM28SS
Lubrication system Wet sump
Engine oil Type SAE SF 10W40, 10W50, 20W40, 20W50
Capacity 3.7 l
Starting system Electric starter and kick
Ignition system Battery and coil (transistorized '79-)
Cylinder numbering method Left to right, 1-2-3-4
Firing order 1-2-4-3
Ignition timing From 20° BTDC @ 1,450 rpm to 40° BTDC @ 2,350 rpm
Spark plugs NGK B8ES
Gap .28-.32 mm
- cjcrug
79 KZ 1000 B3 LTD
Wiseco 1105
Kerker 4 into 1
Dyna s ignition
Dyna green coils
K and n pods
Andrews 2x cams
- 4TheKZ1000
- Visitor
cjcrug wrote: wow thats quite a jump. how much power do you think my setup should make? I havent rode it yet, im refreshing the top end. The po let it sit in a shed for two years with the carbs off, so the pistons were slightly siezed, and thanks for the info
I would guess a 25 to 30 hp jump from a base of 90hp.....somewhere aroun 120 total.
turbos start at about 140hp
Mr. Turbo web info
Power Gains:
Boost / Small CC (900-1000) / Big CC (1200-1400)
10lbs / 140 hp / 170 hp
20lbs / 200 hp / 230 hp
30lbs / 280 hp / 310 hp
- cjcrug
79 KZ 1000 B3 LTD
Wiseco 1105
Kerker 4 into 1
Dyna s ignition
Dyna green coils
K and n pods
Andrews 2x cams
- 4TheKZ1000
- Visitor
cjcrug wrote: what sprockets do you run? I have 15/35. i believe 15/33 is stock. will 15/33 be a good combo for the rest of my goodies, i want good low end but still be able to take it on the freeway
ya I was 14/37 it was way to much.....bike worked way to hard. Went down to 15/35 and like it much better. Im running a 18" not a 16" rear so a 15/33 would work also....will try and see if it works.
Goto Gearingcommander.com and mess arount with it....will learn alot.
- lushbaugh
- everybodys a pro......
- Thank you received: 35
79 kz1000 ltd all apart
the best advice i can give is dont take dnthavakawmans advice..
- wireman
- Thank you received: 299
Mr. Turbo web info
Power Gains:
If youre not having the head ported/polished or installing a healthy set of cams and carbs Id say a 5-10hp gain over what the bike had previously when it was running right if all other parts remain the same is a more realistic number
- lushbaugh
- wireman
The most realistic number Ive seen on a smaller motor was omrs 1st build with the stock bore 1015 wisecos /Larry Cav head/.365 cams and 29 cr's made 95hp.
My ltd made 126hp with a tired 1197 kit/.435 cams in a mediocer head with a set of 38 flatslides,in its defense it had a really soft back tire that was coming apart like a rubber grenade during the dyno runs! :sick: :woohoo:
I never dynoed it after rebuilding the motor with the new bottem end /1327 kit with the turbo pistons/decent head ported by me with .380ish cams and that little ol Garret hair dryer force feeding it,but let me just say when that boost gauge started bouncing between 10-15lbs going down the road Id lose all interest in watching it because I was way to busy seeing my life pass before my eyes! :sick: :sick: :sick: :sick: :sick: :woohoo:
When I swapped the topend for build a carbed version of the 1327 with another set of pistons /a big valve j-head I ported .435 cams /and the old 38 flatslides Id say it realistically made 150-160hp at rear wheel on pump gas with some home made octane booster
- lushbaugh
- wireman
Anyway hes not really good at plumbing/hvac or electrical stuff so we trade lots of favors! :woohoo:
