changed headgasket and now wont start ...???
- andyvr4
28 Nov 2012 22:55 #560397
by andyvr4
1983 kz750 Ltd 4 cyl.
Andy
changed headgasket and now wont start ...??? was created by andyvr4
Hi I have a 1983 kz750 Ltd h4 chain drive. And I just replaced the headgasket and put it all back together and now it doesn't start. I think its my timing I lined up the z7ex with the head on the exhaust cam and counted 45-46 teeth and put the in, between 44-43 cause it looks like the picture. But it says to put it at 45-46 teeth but I'm afraid ill mess up a valve. And i did this all at t1 notch next to f1f4.
Andy
- 4TheKZ1000
- Visitor
28 Nov 2012 23:27 - 28 Nov 2012 23:48 #560399
by 4TheKZ1000
Replied by 4TheKZ1000 on topic changed headgasket and now wont start ...???
sorry but looks like you may have damaged her.
Timing must have been off. Just a few teeth off on chain or cam oriention wrong and a valve can come into contact with the piston.
I would guess no noise if you try to start...like backfire or any sign of bike turning over or tring to run?
I would try to correct timming first, this can keep further damage from happing if any at all.
Then if bike turns over a compression check would be in order. If that is ok the valves are fine.
Last edit: 28 Nov 2012 23:48 by 4TheKZ1000.
- bountyhunter
- Thank you received: 337
29 Nov 2012 03:21 #560426
by bountyhunter
Replied by bountyhunter on topic changed headgasket and now wont start ...???
what's the compression read?
- andyvr4
29 Nov 2012 10:00 #560441
by andyvr4
Andy
Replied by andyvr4 on topic changed headgasket and now wont start ...???
Haven't done a compression test yet will today. But was all at 120 before head gasket change. It did backfire after a couple of cranks. But did not start. I turned the engine over by wrench a few times before start and there was no tapping. All quiet. And even cranking no tapping. Also before all this I did the dynojet kit install and this is the first attempt to start it.
Andy
- Thank you received: 2098
29 Nov 2012 11:16 - 29 Nov 2012 11:21 #560450
by Patton
Replied by Patton on topic changed headgasket and now wont start ...???
On some models it's possible to install the timing advancer rotor 180° out.
When the pointer (stock igniter) or embedded magnet (Dyna-S) passes by the left-side pickup module, it ungrounds whichever ignition coil is connected to the left-side pickup module, which causes the ignition coil to fire.
When the pointer (stock igniter) or embedded magnet (Dyna-S) passes by the right-side pickup module, it ungrounds whichever ignition coil is connected to the right-side pickup module, which causes the ignition coil to fire.
Last edit: 29 Nov 2012 11:21 by Patton.
29 Nov 2012 11:25 #560452
by Patton
If needed -- wiring diagram from FILEBASE:
Click > www.kzrider.com/filebase/doc_download/317-z750h4
- andyvr4
29 Nov 2012 13:17 #560470
by andyvr4
Andy
Thank you ill check this out also
Andy
- andyvr4
29 Nov 2012 23:31 #560572
by andyvr4
Andy
It was my timing got it right now, now I just need to get my jets situated thank you for the help
Andy
