KZ650 Cylinder head Compatability
- TJMD
- DoubleDub
- Visitor
A 750 head can work as long as it has the holes for the top idler and the indentations for the tensioner and front idler on the underside. That said - it will reduce your compression as the 750 has a slightly larger compression chamber in the cylinder head. It also has larger valves than the 650 which may adversely affect your performance without other changes as well.
- gd4now
- Denco where did you go?
- Thank you received: 439
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
- steell
gd4now wrote: Any of the heads from (K)Z650 1980 (US market) and before should work without issue. The later ones used a different cam chain hy-vo and do not have the necessary flanges/bolt holes for the older style cam chain top idler.
Are you sure about that? It's kind of weird that the 650s have no provision for the roller cam chain while the 750s do.
- gd4now
Again, it is my understanding that some of the eary 750 heads do still have the bolt holes for the original idle wheel but the later 750 and 650 heads do not.
1977 KZ650 B1
- TJMD
- DoubleDub
- Visitor
gd4now wrote: It is my understanding, and I am not claiming to know all, when the change to the Hy-vo cam chain happened the top idler wheel was removed as well as the bolt holes for it from the head. Instead a plastic or plastic like shim was installed on the cam cover to take up some of the slack in the cam chain between the to cam sprockets.
Pretty sure the holes are still there and tapped to take the top roller. That's the way the Kz750's with the Hyvo chain came. As long as he still had the chain roller and other equipment it should work no matter what year.
- WABBMW
- Let The Good Times Roll !
- Thank you received: 16
From studying heads on ebay, I think that the castings were threaded up through 1980. 1981 and later switched to the hy-vo chain and no center idler, nor threads in the 4 holes in the casting.
Bill Baker
Houston, Texas
1982 KZ650 CSR
2008 Yamaha FZ1
2006 Yamaha FZ1
1977 Honda Supersport 750 four (sold)
1984 Honda Nighthawk 650 (sold)
