- Thank you received: 1656
KZ650 to 750 Conversion - Cylinder Block & Pistons
20 Jan 2013 20:59 - 12 Feb 2014 07:11 #568366
by martin_csr
Replied by martin_csr on topic KZ650 to 750 Conversion - Cylinder Block & Pistons
Because that would be fibbing.donthaveakawman wrote: why not just get a 750 and tell people you converted a 650 to a 750?
Last edit: 12 Feb 2014 07:11 by martin_csr.
- donthaveakawman
- Visitor
20 Jan 2013 21:12 #568369
by donthaveakawman
Replied by donthaveakawman on topic KZ650 to 750 Conversion - Cylinder Block & Pistons
still going to be 66x54, what about the carbs? 28mm?
20 Jan 2013 21:22 - 28 Jan 2013 12:48 #568372
by martin_csr
The 82-83 650-CSRs have Mikuni BS32 carburetors. All he had to do was up the size of the jets - according to his info, he went one size bigger. Those CSRs have the same frame, carb holders, airbox, & airbox ducts as the 750-4s. So a guy could swap in a complete 750 engine.
Last edit: 28 Jan 2013 12:48 by martin_csr.
- WABBMW
- Let The Good Times Roll !
20 Jan 2013 21:40 #568378
by WABBMW
Bill Baker
Houston, Texas
1982 KZ650 CSR
2008 Yamaha FZ1
2006 Yamaha FZ1
1977 Honda Supersport 750 four (sold)
1984 Honda Nighthawk 650 (sold)
Replied by WABBMW on topic KZ650 to 750 Conversion - Cylinder Block & Pistons
Here in Houston, Texas, there are so many people that the demand for parts is high. This drives the price up. I doubt that I could have found a complete engine for less than $300. and then I wouldn't know the condition either.
So does anybody know the lift for the 750 cams?
Bill Baker
Houston, Texas
1982 KZ650 CSR
2008 Yamaha FZ1
2006 Yamaha FZ1
- zukdave
- Thank you received: 229
20 Jan 2013 22:32 - 20 Jan 2013 22:37 #568389
by zukdave
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
Replied by zukdave on topic KZ650 to 750 Conversion - Cylinder Block & Pistons
Martin I guess i'm a fibber I'll stand flat footed
all daylong and tell you my bike's a KZ650F1
look at the numbers on the neck.
Nobodys bizz why it's a real fast 650.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Last edit: 20 Jan 2013 22:37 by zukdave.
The following user(s) said Thank You: steell, wireman
- WABBMW
27 Jan 2013 12:14 - 29 Jan 2013 01:45 #569510
by WABBMW
Bill Baker
Houston, Texas
1982 KZ650 CSR
2008 Yamaha FZ1
2006 Yamaha FZ1
Thought you might find it interesting to see what I found inside the engine. A previous owner must have let the engine set up for years with moisture within the cylinders. The walls have severe corrosion and pitting. You can even see an area where an oil control ring made an impression in the wall. And then there is one gigantic spot where a deep piece was missing from the cylinder wall - mayby when the engine may have been stuck, and a ring pulled the material from the wall. There is no wonder the engine used oil. And this caused considerable carbon build up on the piston tops. One surprise was that it appeared that something must have gotten into the combustion chambers and caused damage to the pistons. No damage was showing inside the combustion chambers. I have put over 25,000 miles on this engine in the last 5 years. I knew the compression was not up to par, but I had no idea what I would find until looking inside the cylinders with a special scope. After seeing this, I decided to do something about it.
s1302.beta.photobucket.com/user/WABFZ1/l...27805520515150000129
Bill Baker
Houston, Texas
1982 KZ650 CSR
2008 Yamaha FZ1
2006 Yamaha FZ1
Last edit: 29 Jan 2013 01:45 by WABBMW. Reason: added photobucket link
