- Thank you received: 540
Another V.I.N.# Mark II Question
- z1kzonly
I have this one? Engine # KZTOOAE112367.
It came from a legends or dwarf car from 15 years ago.
It is not black at all, probally LTD.
Has the smog head. The cams have the 32 teeth sprockets.
It is oily and dirty and on the ground.
Before I tear into it, I am hoping it is Mark II.
I will be selling cases and the crank.
And are the tranny's beefier?
Thanks for any info.
- Powerstroke_fan
- Thank you received: 83
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
- wireman
- Thank you received: 299
I believe the ltds got the heavier cases in 79 then the big pin crank like the regular mkII motors in 1980.
Ive heard the trans had heavier gears
If yours has the 32t cam sprockets Im gonna guess 80 ltd since its not painted
- RonKZ650
- Thank you received: 240
- gd4now
- Denco where did you go?
- Thank you received: 439
Engine No. Range KZTOOAE111504 -112611
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
- wireman
That would make it a j-series motor if it was in an 81,motor mounts and head would be completely differant.gd4now wrote: Do by all means look for the additional braces on the cases, but the engine number you posted - KZTOOAE112367 - appears to fall within the range used on the '81 KZ1000-C4
how about a picture of the mystery motor in question?
- trianglelaguna
- Thank you received: 235
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- etbike3135
- Thank you received: 50
MKII's did not always have what is thought of as MKII motors either. I have had 2 79's that did not have the extra ribbing.
1973 Kawasaki Z1
18 years in dragbikes
- Powerstroke_fan
etbike3135 wrote: There was an 81 Police bike with the older KZ kick start motor. Police bikes did not follow the civilan production releases.
Ya, it could be a police bike motor.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- z1kzonly
Thanks for all the info so far.
Here are the pics.
I have no idea were it came from.
Only that it was in a small dwarf or legends race car.
I did not tell the kid what these "popy A" grind cams were or
that ported head with the bigger intake boots was anything good! :evil:
It was full of and well oiled sitting there. crank spins just fine!
As soon as my Son lifts it up on my bench, I'll open it up.
Thanks for the info.
- trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
- Powerstroke_fan
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
