- Thank you received: 1
550 gearbox into 750
- rosken
21 Nov 2012 15:53 #559467
by rosken
550 gearbox into 750 was created by rosken
Hi everyone, i am thinking about fitting a 550 gearbox into a 750ltd (h2) engine to fit into my z650, does anyone know how difficult a task this is, i already have the gearbox sprocket offset a lttle bit as i have a 160 back tyre fitted, maybe the shaft on the 550 is not long enough?, any advice on this one would be good
- Nasty610
28 Nov 2012 00:25 #560294
by Nasty610
Replied by Nasty610 on topic 550 gearbox into 750
Yes it will fit. You have to mix and match a few bearings but once you have everything opened up it's pretty apparent what's needed. There is also a 1mm spacer you'll need to make to take up the space between the case and one of the bearings. You can use either the 550 or 750 clutch basket. If you do a search it's been done before and there are several write-ups on it.
- rosken
05 Dec 2012 13:23 #561468
by rosken
Replied by rosken on topic 550 gearbox into 750
ok, i will attempt it over the winter,
thanks for the reply
