- Thank you received: 35
should i?
- lushbaugh
- everybodys a pro......
21 Nov 2012 04:21 #559414
by lushbaugh
79 kz1000 ltd all apart
the best advice i can give is dont take dnthavakawmans advice..
should i? was created by lushbaugh
No eBay APP ID and/or Cert ID defined in Kunena configurationshould i consider this for my street rod turbo build? :evil:
- 4TheKZ1000
- Visitor
21 Nov 2012 08:26 #559419
by 4TheKZ1000
Replied by 4TheKZ1000 on topic should i?
Well if you need to know...give em a call...the guy selling the ebay item is a well known drag racer as the whole family racers....he would be able to help also....
MTC. Performance Products
Street/Strip V-Twin/Metric
800-827-9210 321-636-9480
sales@mtceng.com
sales@mtceng.com
- Powerstroke_fan
- Thank you received: 83
21 Nov 2012 09:20 - 21 Nov 2012 09:23 #559420
by Powerstroke_fan
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Replied by Powerstroke_fan on topic should i?
I am getting ready to get my 1325 kit all gathered up. I would give john pearson a call he can tell you whatever you wanna know. He is building mine right around 9 to 1 comp. So you probally could run that just might mill you head to help bump up the compression some. Not sure if you will have to worry about over heating. But its not cheap to build a big motor like that espically if your starting with a stock block. You will want to run a cooler also. But i would call him and talk to john to be sure.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
Last edit: 21 Nov 2012 09:23 by Powerstroke_fan.
- wireman
- Thank you received: 299
21 Nov 2012 12:39 #559435
by wireman
Replied by wireman on topic should i?
Id say run like hell from that big of a motor on boost till you grow into it,i ran that same set up on my 1327 for a while with a turbo on it before switching pistons and throwing big set of smoothbores back on it.
A little 1015-1075 turbo is capable of making so much more power than a streetable kz 900/1000 chassis can handle and will hurt/kill you just as fast :sick:
- wireman
21 Nov 2012 12:55 #559438
by wireman
Ive still got those pistons to remind myself that that a 1327 turbo motor in an unraked frame with a 3" over arm with a 150 rear tire isnt a really good combination on the street,especially with a pacemaker! :sick: :woohoo:
It would defy all the laws of physics I rememembered from high school as it would smoke the tire while at the same time bring the front end and try and swap ends :woohoo:
Attachment 1327.jpg not found
- Powerstroke_fan
21 Nov 2012 17:05 #559473
by Powerstroke_fan
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
It would defy all the laws of physics I rememembered from high school as it would smoke the tire while at the same time bring the front end and try and swap ends :woohoo:[/quote
Jim, Your gonna have to quit teasing me I know its not done yet and you keep talking about it. It is making me get impatent and drool a lil. :lol: :woohoo: :silly:
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- lushbaugh
21 Nov 2012 17:08 #559475
by lushbaugh
Replied by lushbaugh on topic should i?
ok thanks guys. i know ill never make the power my ducati was built to or my sprayed gsxr750 but i want moooore lol
- wireman
21 Nov 2012 17:17 #559478
by wireman
Baby steps,baby steps!
Its not so much about making power as it is being able to put it to the ground and control it safely
My 1327 with carbs on it would run 6.15s in the 1/8 with no slick and no wheelie bar,and i could still ride it to/from the track.
