Swap short breather cover for a tall one?
Re: Swap short breather cover for a tall one?
20 Nov 2012 22:44
#559370
Absence of commercial self-promotion in the regular discussion forums applies equally to all members.
Good Fortune! :)
  • Jeff.Saunders
  • Jeff.Saunders's Avatar
  • Vendor
  • Vendor
21 Nov 2012 14:01
#559450
Whatever cover you use, make sure the cover is vented, OR you have at least one vent elsewhere on the engine. On my turbo bike, I not only have the vented low-profile breather cover, but two additional vents in the valve cover to assure enough venting. If you don't have enough venting, you'll be amazed at the places oil can puke from.... and then you'll vent...
Personally, I would stay with the baffled tower unless you have a good reason to change.
This email address is being protected from spambots. You need JavaScript enabled to view it.
www.z1enterprises.com
Z1 Ent on Facebook,
  • kzz1king
  • kzz1king's Avatar
21 Nov 2012 21:55
#559533
Does venting the lower end well negate having to do the upper end? I know some vent through the starter area if no electrics. I vented my turbo project through the oil filler. I never had any problems but did not ride it alot, just hard!.
Wayne
Home built KZ1000 turbo setup
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
21 Nov 2012 23:05
#559543
kzz1king wrote: Does venting the lower end well negate having to do the upper end? I know some vent through the starter area if no electrics. I vented my turbo project through the oil filler. I never had any problems but did not ride it alot, just hard!.
Wayne
it doesn’t matter where u vent so much as havening adequate venting.
the question around where u vent, leads to the question, how much oil will splash or exit if i vent in that location.
Hope that makes sense. :laugh:
The stock vent is barely adequate, for a stock motor. Once the ring start to ware u get more blowby and then the stock system starts venting oil with the gasses. Lots of guys add more venting. This also helps prevent gasket leaks.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
