- Thank you received: 1
top end rebuild ????
- poolboy
Cyl
1- 2 - 3 - 4
dry 52, 82, 107, 112.
wet 105, 138, 148, 164.
no wonder I had a hard time starting this bike :S
Does this look like a valve job, and rings. What do you think ????
1980 KZ750H ,WG's carb rebuild, V&H 4-1 Exh ,WG wiremod, Dyna 3.0 ohm coils, Dyna-S EI DS2-2,New Bridgestones, O-ring Chain,
- 4TheKZ1000
- Visitor
did you take all plugs out during comp test?
did you have throttle wide open during comp test?
- OldSchoolZ
- Thank you received: 33
Remember, don't work on your bike so much you never ride it.
- poolboy
I did not know wide open throttle was necessary during comp test, and please explain why that is necessary.
By the way, please understand I'm not a mechanic by any means. I've done a lot of mechanical work, but that does not qualify me as knowing a damn thing. I admire people who are qualified and certified in the field they hold.
- poolboy
- Thank you received: 2098
In order for air to be compressed when inside the combustion chamber, air must first be sucked into the combustion chamber.poolboy wrote: I had the plugs out for the test, did not have the throttle wide open during comp test.
I did not know wide open throttle was necessary during comp test, and please explain why that is necessary....
The supply of air for being sucked into the combustion chamber flows through the carbs.
If the carbs throttle slides are closed down, the air can't flow through the carbs, whereby there's no air sucked into the combustion chamber, and therefore no air to compress.
- wireman
- Thank you received: 299
If it ran good before maybe try dumping just a little trans fluid mixed with gas down the plug holes and let it sit and work on the rings for a while,youve got nothing to lose
- poolboy
Heres results for todays test.
cyl 1 2 3 4
old test
dry 52 82 107 112
wet throttle closed 105 138 148 164
todays test
wet throttle wide open 116 178 205 235
heck of a difference guys.
I can see why having an open throttle is important.
It ran good before I parked it 3 years ago wireman.
Thanks Mr Patton for the explanation, I read your articles a lot, thanks.
And 4TheKZ1000 , I did have the plugs out during test.
OldSchoolZ, I will look at valve clearance before I tear it apart.
I will try wiremans advice and soak it with trans fluid and gas.
Thanks guys for the advice, I will follow it.
I'll post again soon.
- 4TheKZ1000
- Visitor
poolboy wrote: Wow, I did another comp test today and the results were dramatic.
cyl 1 2 3 4
old test
dry 52 82 107 112
todays test
There are so bright guys on here about KZ issues....use and abuse them..... :woohoo: :woohoo: :woohoo:
