So I was looking at my bike...
- antoniobanderas
18 Nov 2012 21:55 #559041
by antoniobanderas
1980 550
Work in Progress
So I was looking at my bike... was created by antoniobanderas
No eBay APP ID and/or Cert ID defined in Kunena configuration.. And the damn ignition timing advancer is missing. My question is will it hurt the bike if I ride it without the advancer for a while? Also does anyone know where the heck I can find one of these things?
This is the only one i have found I am pretty sure it is what i need.
1980 550
Work in Progress
- 4TheKZ1000
- Visitor
18 Nov 2012 21:59 - 18 Nov 2012 22:01 #559044
by 4TheKZ1000
Replied by 4TheKZ1000 on topic So I was looking at my bike...
Really....??? please take a pic and post.... :whistle:
Are you running points or electronic ignition.
does the bike run now....?
Last edit: 18 Nov 2012 22:01 by 4TheKZ1000.
- antoniobanderas
18 Nov 2012 22:05 #559045
by antoniobanderas
1980 550
Work in Progress
Replied by antoniobanderas on topic So I was looking at my bike...
Well I am assuming that the advancer comes out of the right side of the engine under a cover. When I got the bike the cover was broken off but I didnt think anything of it. There appears to be a cam lobe coming out and I can rub my finger all the way around it. There are also 4 wires coming out of the case that run to the ignitor.
The bike is in a friends garage so I can not take any pictures.
1980 550
Work in Progress
- 4TheKZ1000
- Visitor
18 Nov 2012 22:15 #559047
by 4TheKZ1000
What bike are we talking about year...model...size...
with the point mount plate or a DYNA-S plate on you cant see the advancer....it would be hidden behind this plate. really dont know what you have going on.....
- 4TheKZ1000
- Visitor
18 Nov 2012 22:31 - 18 Nov 2012 22:35 #559048
by 4TheKZ1000
do you have one of these....
Attachment 059325x357.jpg not found
Last edit: 18 Nov 2012 22:35 by 4TheKZ1000.
- z1kzonly
- Thank you received: 540
19 Nov 2012 00:51 #559073
by z1kzonly
Replied by z1kzonly on topic So I was looking at my bike...
You probally got a fully advanced drag race unit. These guys would weld a stock unit to fully advanced so it would be 25 to 40 degrees fully advanced timing.
These guys used car starters on the big crank end. And did not use stock 700-800 rpm idle speed.
If it is welded solid, the advance unit. It is from a drag bike engine.
- Old Man Rock
- Thank you received: 225
19 Nov 2012 07:23 - 19 Nov 2012 07:25 #559093
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic So I was looking at my bike...
Cam lobe.... ?
Pictures required...
In either case (OEM or Dyna), ignition advance resides behind the ignition timing plate.
OEM Ignition (Points & Condensor)
Dyna-S (Electronic Ignition Pickups)
Look through the timing plate top hole for advancer marks...
Incase you truly do require...
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 19 Nov 2012 07:25 by Old Man Rock.
