- Thank you received: 5
Clutch issues?
- Mr.Wizard
18 Nov 2012 05:06 #558922
by Mr.Wizard
Clutch issues? was created by Mr.Wizard
Full disclosure: I have no idea what I'm talking about, so bear with me.
Recently bought a 440 and love it. I was driving on the interstate when I had a total loss of acceleration so I pulled over and did some experimenting. The engine idles and rev's fine, but there's only the slightest hint of power going to the wheels. I cracked the right side, cleaned everything up and replaced the very worn clutch plates, but still nothing.
The bike seems to be a hodge podge of KZ parts, so I'm not sure how accurate each manual I'm following is, but I noticed that my model didn't have the small sphere (bearing?) that should be inside the center of the clutch plate assembly, the rod that goes behind the bearing has a little play in it (Which seemed like how it's supposed to work?). The gears all seem to be shifting fine, I just can't get enough power to actually move.
Theres a slight clacking when I rev it and let the clutch past the friction zone, but I haven't given it much because I'm worried I'll make whatevers wrong worse.
Any ideas? Do I have a ground down something or another in my transmission? Please help, I'm dying without my bike!
UPDATE:
Did more research, the engine is the same style as the "1982 KZ440D3 LATE MODEL" with the clutch cable connecting on the right side. It has a double sided spring plate pusher and doesn't use the spherical ball or have a clutch push rod assembly from the left side of the bike. I opened her back up and everything looks like it's assembled correctly based on that manual. I pulled out the clutch arm that the cable attaches to and shined a light into the hole facing down, I can see the end of the spring rod pusher clearly, it looks and feel like it's engaging fine.
What the hell gives?
UPDATE:
- Thank you received: 2098
18 Nov 2012 07:00 - 18 Nov 2012 07:01 #558926
by Patton
Replied by Patton on topic Clutch issues?
If not already done, would also take a look at
www.armbell.com/forum/index.php?c=6&sid=...571a51a&mforum=kz400
www.kz400.com/
home.comcast.net/~loudgpz/GPZweb/Mnls/Mnls.html
www.kz400.com/
Last edit: 18 Nov 2012 07:01 by Patton.
- Mr.Wizard
18 Nov 2012 12:54 #558953
by Mr.Wizard
Replied by Mr.Wizard on topic Clutch issues?
Already posted the same exact thread there . Ive scoured the appropriate engine manual to no avail
- Mr.Wizard
18 Nov 2012 16:13 #558984
by Mr.Wizard
Figured it out, stripped to hell front pulley. Looks like it was machined smooth, not a single tooth left.
- wireman
- Thank you received: 299
18 Nov 2012 16:38 #558989
by wireman
Replied by wireman on topic Clutch issues?
Belt drive pulley?
If it chewed up a pulley Id say the belt and other pulley arent long for world.
- wireman
19 Nov 2012 11:47 - 19 Nov 2012 11:48 #559118
by wireman
Cant seem to find a front pulley part number
Attachment Image.gif not found
Last edit: 19 Nov 2012 11:48 by wireman.
