Valve clearances and timing
- Mirbooya
The bike has always ran a little rough on start up, then idle high (1500 rpm) when warmed up. This could explain the lack of valve clearance as the partly opened valve would cause it to run lean when warmed up. My question though is about the timing, would it even run with what I have noticed? It was running not too bad and I am second guessing my observations.
1981 Z750 L1
- Mirbooya
Attachment ImageUploadedByTapatalk1353226100.261107.jpg not found
Here is an image of the instruction I am following. I need to get some thinner shims to correct the clearance, when I do I can post an image of how it is set up
1981 Z750 L1
- Mirbooya
Patton wrote: These links are to info and suggestions contributed by RonKZ650:
www.kzrider.com/forum/2-engine/475461-re...ving-the-cams#475461
www.kzrider.com/forum/2-engine/249136-re...seating-issue#249136
www.kzrider.com/forum/2-engine/221680-revalve-clearance#221680
www.kzrider.com/forum/2-engine/146192-revalve-shims#146192
www.kzrider.com/forum/2-engine/21185-re6...lve-clearances#21185
Seems there is much info about this topic on this site. The above posts are very helpful.
1981 Z750 L1
- Mirbooya
Here are some images of the timing as now corrected. As I mentioned in the original post, the inlet cam was set two pins further around (anti-clockwise when viewed from the photo). I have turned it over by hand, pulling the chain tight in the middle of the two cams, and all appears to be o.k. Wondering if anyone had any comment?
1981 Z750 L1
- Mirbooya
The job was very daunting at first, but after reading up on the manual and all the great information on this forum, it became much more approachable.
1981 Z750 L1
- Motor Head
- Thank you received: 391
Good to hear you got it sorted and the bike runs much much better I bet.
- Thank you received: 2829
