Installing seal in tach drive
  • Patton's Avatar Topic Author
17 Nov 2012 16:12
#558813
When fitting a new seal into the tach drive housing, which end of the seal (small end with spring A, or large end without spring B) goes in first?
Good Fortune! :)
  • MFolks
  • MFolks's Avatar
Re: Installing seal in tach drive
17 Nov 2012 16:26
#558816
I believe "B" is the correct position. Did the old seal vanish?
17 Nov 2012 16:50
#558818
I recall installing mine as shown in figure "A", and I think that's how it was originally installed. I may be wrong, but I am under the impression that the spring side of any seal faces the inside of the object being sealed and the smooth side faces the outside. Ed
  • 4TheKZ1000
  • 4TheKZ1000's Avatar
17 Nov 2012 16:58 - 17 Nov 2012 16:58
#558819
If I was to guess and I am..... :laugh:
I would think that the proper way is "B"
Im not just saying "B" to kiss Ed's azz..... :woohoo: :woohoo: :woohoo: :woohoo:
Last edit: 17 Nov 2012 16:58 by 4TheKZ1000.
17 Nov 2012 19:29
#558838
Seals go in with spring side facing in / flat side facing out. This way any pressure inside the engine pushes the seal lips tighter against seat. Otherwise pressure can push oil past seal. Flat side of seals generally fit flush or slightly recessed in housing. Also make removing old seals possible by punching 2 holes in flat side and pulling seal out. Take a look at every other seal on your engine or the front forks; flat side always faces out. ;) Ed
  • 4TheKZ1000
17 Nov 2012 20:58
#558853
650ed wrote: Seals go in with spring side facing in / flat side facing out. This way any pressure inside the engine pushes the seal lips tighter against seat. Otherwise pressure can push oil past seal. Flat side of seals generally fit flush or slightly recessed in housing. Also make removing old seals possible by punching 2 holes in flat side and pulling seal out. Take a look at every other seal on your engine or the front forks; flat side always faces out. ;) Ed
Sounds like Ed knows alot about Lips.....scarry..... :ohmy:
  • KZJOE900
  • KZJOE900's Avatar
  • Administrator
  • Administrator
    Super Users
17 Nov 2012 21:06
#558858
I'm with Ed on this one. When I changed mine was I very mindful of the orientation of the old one while taking it out. So, I'm pretty sure it was version A.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
  • DesertKZ
  • DesertKZ's Avatar
17 Nov 2012 21:30
#558861
Version A. Don't drive the new seal all the way in, just flush, and let the tach cable seat it.
1979 KZ1000 Shaft
1979 CX500C
1975 GT750 Smoker
  • Garn
  • Garn's Avatar
19 Nov 2012 05:05 - 19 Nov 2012 05:08
#559091
650ed wrote: ........Take a look at every other seal on your engine or the front forks; flat side always faces out. ;) Ed
I have laboured over this some time ago, I believe its "A" in first.
The above quote of 650Ed is interesting.... I have to agree, I can't think of any seal that have the spring side showing its always the flat side out!
RegardZ.
1 x 73 Z1 (Jaffa), 74 Z1A, 76 Z900-A4
1 x 73 Yamaha TX500 & 98 fzx250 Zeal
Sydney Australia
Last edit: 19 Nov 2012 05:08 by Garn.
  • undiablo
  • undiablo's Avatar
19 Nov 2012 11:35
#559115
I agree with Ed. The correct mounting position is A. ;)
Kawasaki KZ 750/4 LTD 1981
Kawasaki KLR 650 2011
Argentina - Buenos Aires
  • yorkshirekid
  • yorkshirekid's Avatar
28 Sep 2021 22:47 - 29 Sep 2021 14:44
#855894
I've bought a tach seal kit for my z900 A4 and cannot fit the large sping oil seal. It just sits on top of the housing.
pic1 - shows the old oil seal before I dug it out. It is clearly inside the housing.
pic2 - shows the cleaned out housing
pic3 - shows the housing with a new seal on the outside from the kit
pic4 - seal will not go inside housing.
Anyone help me with this please - thank you
Last edit: 29 Sep 2021 14:44 by SWest.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
29 Sep 2021 12:09 - 29 Sep 2021 12:43
#855913
Your old seal outer body is not completey removed from the tach gear housing!!!
EDIT, add a pic of the empty tach gear housing
Last edit: 29 Sep 2021 12:43 by Scirocco.
The following user(s) said Thank You: DOHC, SWest, Rick H.
