Head Crack
- 4TheKZ1000
Head Crack
15 Nov 2012 22:24 - 15 Nov 2012 22:44
On my old MarkII cyclinder head....I have a crack between the valve seats on one cyclinder (see pic) is this head scrap or can it be used. I had a well known engine builder tell me its ok to use...whats the forum think.....?
Also....its a complete head....any value or take to scrap yard.
Attachment 027.JPG not found
Last edit: 15 Nov 2012 22:44 by 4TheKZ1000.
- Motor Head
Re: Head Crack
15 Nov 2012 22:32
They can be repaired of course, but the cost compared to a good head, that's the issue.
I'd chose either before running it that way, as the seats can come loose, possibly causing piston and valves to hit. Could be Ugly, if the piston breaks, :sick:
- 4TheKZ1000
Re: Head Crack
15 Nov 2012 22:36 - 15 Nov 2012 22:36
Oh by the way....nice plug repair....some hack worked on it.... :sick: :sick: :sick:
Last edit: 15 Nov 2012 22:36 by 4TheKZ1000.
- gpz1170
Re: Head Crack
15 Nov 2012 23:50
Contact John Pearson quite sure he can help
don
don
1974 Z1
1976 KZ900
1978 KZ1000
1981 KZ1000
1983 GPZ1100
1976 KZ900
1978 KZ1000
1981 KZ1000
1983 GPZ1100
- wireman
Re: Head Crack
16 Nov 2012 03:13
Unless its had a lot of money spent on a porting job in the past id say theres nothing special about it ,just hang on to it if you needs parts like fin pieces to weld on to another good head.
Ebay is full of those ugly 79-80 smog motor heads,yeah I prefer the looks of older ones myself! :laugh:
- APE Jay
Re: Head Crack
16 Nov 2012 05:28
Most of the KZ heads that come thru the shop are like that. Unless you are turboing it of running big nitrous load, you won't have a problem with it.
- LarryC
Re: Head Crack
16 Nov 2012 08:49 - 16 Nov 2012 08:51APE Jay wrote: Most of the KZ heads that come thru the shop are like that. Unless you are turboing it of running big nitrous load, you won't have a problem with it.
I received photos just the other day from someone asking that question....I gave the same answer.
Generally I see that on old 900 heads and not on the 1000 heads.
I've never seen the cracks cause a problem on any n/a KZ. Those seats are not going to fall out. That's for dam sure...
Larry C.
Last edit: 16 Nov 2012 08:51 by LarryC.
The following user(s) said Thank You: 4TheKZ1000
- APE Jay
Re: Head Crack
16 Nov 2012 20:13
The very first Z1s had a larger exhaust seat in them. You could put 32mm valves in them. However, all of them must have cracked from the seat to the spark plug hole, so Kawasaki went with a smaller OD seat to give it more room. But they still do that.
- kzz1king
Re: Head Crack
16 Nov 2012 21:28
IMA going to pullmine and check
Home built KZ1000 turbo setup
- wireman
Re: Head Crack
17 Nov 2012 00:00
Ive got several z1 heads and none of them are cracked between the seats,Im not aware of any of my kz heads having that problem either.
- Galactica
Re: Head Crack
18 Nov 2012 21:02
I have a kz900 head with a crack between the exhaust valve and the spark plug on the #3 chamber.
77KZ1000
76 KZ900
76 KZ900
- guitargeek
Re: Head Crack
26 Nov 2012 18:28APE Jay wrote: Most of the KZ heads that come thru the shop are like that. Unless you are turboing it of running big nitrous load, you won't have a problem with it.
I was sure glad to read this last night! I had a bad moment when I found these:
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
