- Thank you received: 1
Engine case broke
- Vranasaurus
When installing the crankcase breather cover I over tightened the bolt and the engine case broke. I attached a pic of the broken piece
Can I just have the piece welded back in or do I need to get a new engine case?
It goes without saying that I'm an idiot.
1984 ZN1100
1975 Z1B
- 4TheKZ1000
- Visitor
- Thank you received: 2829
- Vranasaurus
But in stripping it down to get the engine out I found what may be one of my problems. There was no exhaust clamp on one of the pipes coming out of the head where it meets the rest of the exhaust.
1984 ZN1100
1975 Z1B
- Motor Head
- Thank you received: 391
- Galactica
Looks like you are looking at an engine rebuild, or find another engine. Sorry for your misfortune. I've done many similar things myself.
Cheers,
Ross
77KZ1000
76 KZ900
- DesertKZ
- Thank you received: 20
1979 KZ1000 Shaft
1979 CX500C
1975 GT750 Smoker
- Nebr_Rex
- Thank you received: 300
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
- Vranasaurus
I pulled the engine and dropped it off at the shop to be welded. I've been needing to tear into the bike any way and replace the o-rings and seals in the final drive. I kept putting it off but no better time than now I guess. Pulling the engine by yourself is no fun.
I will post pics when I get it back.
1984 ZN1100
1975 Z1B
- 4TheKZ1000
- Visitor
Vranasaurus wrote: I did try JB weld and it didn't hold up. I have an evinrude that has jb weld for part of the water pump housing and it's holding up great after 5 years.
Oil will mess with a bunch of stuff....alum is so porous and holds oil deep inside the material.....hard to get a good bond.
- Vranasaurus
1984 ZN1100
1975 Z1B
- donthaveakawman
- Visitor
