STARTER ISSUE KZ 650
  • PRACTIKALGUY
  • PRACTIKALGUY's Avatar Topic Author
15 Nov 2012 15:37
#558497
I have a 1980 KZ650F. The starter works fine when the engine is cold but, when it's hot, the starter half engages and half grinds. I'm not sure if it's a bad clutch, solenoid, or starter. Any ideas? Thanks.
  • Motor Head
  • Motor Head's Avatar
Re: STARTER ISSUE KZ 650
15 Nov 2012 22:21
#558554
Anyway to post a Video with a sound Byte? Otherwise it guess work for sure. Starter clutches are a common failure and do make a lot of noise.
  • tinlizzie37
  • tinlizzie37's Avatar
16 Nov 2012 15:45
#558662
Double check the type of oil you have in the crankcase. If it's a motorcycle type oil, then the clutch needs replaced, otherwise change the oil you have i n to a motorcycle type without all the friction inhibitors. Bob
Bob KZ 650 E1, En 450
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
16 Nov 2012 22:10
#558728
Welcome.
Do post up some pictures of your KZ.
B)
Some info on the starter clutch, which I'd say is what your hearing:
forums.kz650.info/index.php?topic=2482.0
forums.kz650.info/index.php?topic=5152.0
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
