- Thank you received: 391
Started, then died, unknown cause
- Motor Head
15 Nov 2012 22:16 #558551
by Motor Head
Replied by Motor Head on topic Started, then died, unknown cause
After a Bike has set for years with fuel in the carbs, they will be needing a through cleaning. Paying close attention to the small circuits, Pilot, Transition and Starter circuits. These will be blocked which will give you fits, until you clean the carbs properly.
Also check your float valve O-rings, where the valve seat goes into the carb body. These will be junk, replace those. The float cannot control fuel entering the bowl from bad O-rings. So flooding, incorrect fuel level is the result.
- Thank you received: 2098
15 Nov 2012 22:22 #558555
by Patton
Would suspect a less than perfectly clean as new pilot circuit.
Carbs at hand are most likely as shown in the diagram posted by 650ed, being CV (constant vacuum) as opposed to manual slide carbs. Function of the float valves and floats are basically the same in both carb styles.
Here's one method to help clean the pilot circuit using carb cleaner spray.
Wear eye protection, because the spray always backfires. Always.
And be sure the "plugs" are fitted during re-assembly.
Replied by Patton on topic Started, then died, unknown cause
johnjones750csr wrote: ...Giving it any more than a little tiny bit of throttle results in the bike hesitating and then dying immediatly....
- Thank you received: 2829
15 Nov 2012 23:03 #558571
by 650ed
Replied by 650ed on topic Started, then died, unknown cause
Be sure to check the carb holders for leaks. I suggest you try the following. Get the engine running and idle it down as low as it will idle. Spray carb cleaner around the carb holders, especially where they mate with the cylinder head. If the engine dies or seems to react to the carb cleaner, you need to replace the carb holders. Ed
- johnjones750csr
15 Nov 2012 23:24 #558576
by johnjones750csr
Replied by johnjones750csr on topic Started, then died, unknown cause
bs34 is the same as the mikuni I assume? Good info, damn I might as well go find a full carb rebuild kit and take the body's down to get cleaned properly. All of this putting on and taking off is really an annoyance. Those little pipes between the carbs and the airbox are really aggrivating lol
- Motor Head
15 Nov 2012 23:32 #558577
by Motor Head
Z1enterprises has the carb kits, the Airbox to carb boots as well as the carb holders/ intake manifolds. Not as cheap as other models but it sure makes it easier to get the carbs in and out.
www.z1enterprises.com/ItemDetails.aspx?i...80-85&item=KL18-2452
- johnjones750csr
16 Nov 2012 10:57 #558621
by johnjones750csr
Well, I took the carbs apart again today, and found a clogged pilot jet on the right side carb. Completely clogged, of course it doesn't take much, the hole is so damn tiny. So I cleaned it out wiht a twist tie, it was just the right size to go through the hole. I'll get it all back together in a little while, all of the other orfices were clean as a whistle. Just the one clogged pilot jet. Also, I can't get the screws loose on the drains for the float bowls so I can't check the float level. I'll see what this new clean jet does. Hopefully it'll make it run a little better.
John Jones
1982 750 CSR Twin
John Jones
1982 750 CSR Twin
