Will Z650 underbucket shims fit the Z9/ z1000?
- Bozo
- Ride it like u stole it
13 Nov 2012 22:12
Just curious. There are some messages flying about on the forum RE: z650 underbucket shims. My question is do these fit the bigger motors and if so why are they not used in preference to the above bucket shims?.
- 4TheKZ1000
Re: Will Z650 underbucket shims fit the Z9/ z1000?
13 Nov 2012 22:22
Im not sure....but the 650 buckets fit 900 1000....so I would assume that the bucket under shims do also.
13 Nov 2012 22:34
Hi Bozo
650 buckets work in 900 / 1000 motors. Good design imo.. Trouble is if you want to call it that is the cams need to be removed to do a shim adjustment. Some hi lift cams need shim under buckets to prevent cam lobes from possibly lifting a shim out of a on top bucket. To convert to shim under buckets you need to also replace the valve spring retainers. Go on the APE web site for more info.
But unless shim under buckets are needed for your cams ,I prefer the shim on top buckets for a street motor
I do love that Z1R of yours
- Powerstroke_fan
13 Nov 2012 22:40
It is a pain to have to pull the cams every time you adjust your valves. not to mention worring about stripping cam cap bolts holes.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- APE Jay
14 Nov 2012 02:05
The 650 buckets fit, but their surface hardness can't handle the spring pressures that are run in the 900/1000s with big cams.
- Bozo
14 Nov 2012 03:15 - 14 Nov 2012 20:20
Thanks guys, the question was actually put to me by a person who is interested in Z900's, one of his desires is to hot the bugger up to blazes.
Personally with my setup I'd never consider shims under buckets for the reasons given.
Last edit: 14 Nov 2012 20:20 by Bozo.
