KZ 750-4 Spark Plug caps or covers
- undiablo
10 Nov 2012 14:05 - 10 Nov 2012 14:06
Well today I took my multimeter and try to measure the resistance of my spark plug caps. Bike is 100% stock as far as I know. For my surprise the resistance was zero (0) ohms. The only information I can read on them is: "NGK Made in Japan".
Researching at NGK web page, I found this:
Looking at my spark plug caps...they are VERY similar to the NON RESISTOR caps.
Since I am using B8ES non resistor plugs...it is OK/safe?
Attachment sparkplugcovers.JPG not found
Kawasaki KZ 750/4 LTD 1981
Kawasaki KLR 650 2011
Argentina - Buenos Aires
Last edit: 10 Nov 2012 14:06 by undiablo.
Re: KZ 750-4 Spark Plug caps or covers
10 Nov 2012 14:56 - 10 Nov 2012 15:02undiablo wrote: Well today I took my multimeter and try to measure the resistance of my spark plug caps. Bike is 100% stock as far as I know. For my surprise the resistance was zero (0) ohms. The only information I can read on them is: "NGK Made in Japan".
It's perfectly okay and safe to run zero resistance throughout the entire secondary loop:
Solid metal core spark plug wires;
Zero resistance caps;
Non-resistor spark plugs.
Where resistance is desired to reduce electrical interference (such as in radio reception, for instance), it's okay to run one and only one resistor component in the secondary loop:
Either resistor plug wires OR resistor caps OR resistor spark plugs.
Combining more than one resistor component in the secondary loop will reduce spark quality.
Kawasaki elected to use resistor spark plug caps as the one resistance component.
I prefer running zero resistance in the secondary loop, using solid core Dyna plug wires, which come with pre-fitted non-resistor caps, and non-resistor spark plugs. However, this probably causes some grief to nearby boom-box listeners.
Sorry, steell :lol:
Last edit: 10 Nov 2012 15:02 by Patton.
10 Nov 2012 19:16
On my KZ650-C1 the sparkplug caps and the sparkplugs are all non-resistor type. They have been that way for the past 35+ years. Ed
- undiablo
11 Nov 2012 19:17
Thanks for the info Patton!
- undiablo
11 Nov 2012 19:19
Thanks Ed,I will keep that way too. Why change if it is working OK? :whistle:
