kz750 twin won't shift into second
  • gumby prichard
  • gumby prichard's Avatar Topic Author
09 Nov 2012 22:09
#557686
hey guys, so i have lately been building my own rearsets seeing as how you can turn the pegs around on a 750. Well i bought an en500 lever and it seemed like it would work, i just needed to extend the area from the lever to where the linkage ball mounts so when i push down i have more travel in the linkage. anyway FINALLY got that welded up today. I put it on and it was acting like it still didnt have enough travel. so i put the old shifter back on to be sure, and now i cant get the thing to shift into 2nd with the old shift lever!
it will shift from 1st to neutral and back but it will not go to second!, i have rocked it while in gear, even started it and tried to shift to second without clutch i though maybe it would catch, but nothing!
any ideas? the only thing i can thik is the shifting fork got off track or something. Anyone have pics of dissasembling the shifters to this thing etc?
thanks,
gumby
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
  • gumby prichard
Re: kz750 twin won't shift into second
09 Nov 2012 22:21
#557688
btw last week i rode it and it shifted and went through all gears fine.
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
  • Jeff.Saunders
  • Jeff.Saunders's Avatar
  • Vendor
09 Nov 2012 22:21 - 09 Nov 2012 22:22
#557689
Those transmissions have a neutral finder - you cannot shift into 2nd by design with the bike stationary... not an issue...
If you get the rear wheel off the ground and spin it, usually that's fast enough for you to get the transmission into 2nd.
I think 1978 was the first year Kawasaki had this feature on the 750 twins.
This email address is being protected from spambots. You need JavaScript enabled to view it.
www.z1enterprises.com
Z1 Ent on Facebook,
Last edit: 09 Nov 2012 22:22 by Jeff.Saunders.
The following user(s) said Thank You: wireman, gumby prichard
  • gumby prichard
09 Nov 2012 22:39
#557696
thats what year mine is! thanks for the info ill try it out! ps love you guys. ill be flying my z1 stickers high!
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
  • Del_Herring
  • Del_Herring's Avatar
10 Nov 2012 00:58
#557720
hehe. I actually really like that feature, but it catches everyone, including me, by surprise the first time, and we all think we've killed our transmissions.
1983 KZ750-N2 Spectre
The following user(s) said Thank You: gumby prichard
