Steps to determine cause of bike smoking
- tmerkl
08 Nov 2012 19:16 #557537
by tmerkl
Steps to determine cause of bike smoking was created by tmerkl
Hey guys, I just bought a 1983 Kz1000 police bike. It starts easily but smokes pretty bad. I'm totally new to the bike world and need some help figuring out what to do next. I've read that this can be caused by anything from carbs needing adjustment to valve seals to rings. What do I do first to figure this out? And second and third for that matter. It sounds good and runs smooth but just smokes so bad I could trade places with the mosquito truck...
- polarbear
08 Nov 2012 19:37 - 08 Nov 2012 19:37 #557539
by polarbear
Replied by polarbear on topic Steps to determine cause of bike smoking
Hello and welcome.
I am sorry, I cannot help you since my mechanic skills are limited. I will however follow this thread because my kz550 ltd also smokes from side (but it has been sitting for about 10 years and may only need to run for a while, or maybe some carb cleaner, who knows).
Lots of very knowledgeable people here, I'm sure someone competent will chime in soon. I hope you can find the problem. Good luck!
Cheers,
C
Cheers,
C
Last edit: 08 Nov 2012 19:37 by polarbear.
- baldy110
- Thank you received: 512
08 Nov 2012 19:37 #557540
by baldy110
Replied by baldy110 on topic Steps to determine cause of bike smoking
If it's been sitting for a while it can also smoke from stuck rings, it can be also caused by old oil. I have had a few that I get started and just run it for a bit and it clears up. I would start with changing the oil and run, see what happens.
- Thank you received: 2829
08 Nov 2012 19:44 #557541
by 650ed
Replied by 650ed on topic Steps to determine cause of bike smoking
You may want to perform a leak down test. If you do a search on this site I believe you will find info on it. Ed
- wireman
- Thank you received: 299
08 Nov 2012 20:18 #557544
by wireman
Replied by wireman on topic Steps to determine cause of bike smoking
What color is the smoke,black or blue/grey?
- polarbear
08 Nov 2012 20:43 #557548
by polarbear
Hi folks,
Sorry to jump in like this, but what does black smoke mean? Mine's blue-ish, which means oil is being burnt, right? Not sure what black means... Sorry for being so ignorant about this--I'm sure it's basic to many of you.
C
C
- tmerkl
08 Nov 2012 21:00 #557553
by tmerkl
Replied by tmerkl on topic Steps to determine cause of bike smoking
I would say it is blue to blue-gray color. The reason he said he stopped riding it was because the smoking was getting worse so I'll definitely try the oil change but not really hopeful about that. It looks like it smokes more on the right side (as you're sitting on the bike) than the left. He said it had been sitting a few months but all I had to do to get it to fire up was put in some fresh gas, top off the oil and pull out what I assumed was the choke on the left side. It took a few times to get the gas flowing but then and on subsequent starts it fires right up. I will say that I think it was smoking a lot worse when I had the choke pulled all the way out than later when I pushed it in. Maybe that's just a coincidence, not sure.
- Thank you received: 2098
08 Nov 2012 22:18 #557571
by Patton
Replied by Patton on topic Steps to determine cause of bike smoking
Black smoke from the exhaust may result from incomplete combustion, for whatever reason, and emit a gasoline odor.
Blue smoke from the exhaust is usually oil burning, for whatever reason.
Blue smoke that's worse when a cold engine is first cranked up and run, and then smokes less after a few miles when the engine has warmed up, may result from deteriorated valve stem seals.
- wireman
08 Nov 2012 22:22 #557573
by wireman
Black smoke is generally fuel related while the blue/grey tends to be oil.
When does it smoke,on start up/under power when you get into it or when you back off the throttle?
If its a new bike to you and you dont know its history Id get it nice and hot and change oil/filter first,then toss some new plugs in it and throw some sea foam in the gas tank and take it out and ride the wheels off of it for a 100 miles or so and see if the condition changes then report back with your findings
- tmerkl
12 Nov 2012 19:05 #558094
by tmerkl
Oil filter has been ordered, so I'll pick up some new plugs and that report will be up soon. Also, while i'm changing the plugs i'd imagine a compression test would help to determine the shape the rings are in, correct?
- tmerkl
12 Nov 2012 19:07 #558095
by tmerkl
Oh yeah, here's the beast in question.
- Powerstroke_fan
- Thank you received: 83
12 Nov 2012 20:03 #558110
by Powerstroke_fan
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Replied by Powerstroke_fan on topic Steps to determine cause of bike smoking
i would do a compression check while the plugs are out.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
