- Thank you received: 5
clutch and generator cover gaskets
- jbeebe1
07 Nov 2012 00:33 #557335
by jbeebe1
79 Honda 400 Hondamatic
79 Honda CB650
81 Honda CX500
81 Honda Passport C70
others coming in and out all the time!
clutch and generator cover gaskets was created by jbeebe1
I removed my engine covers for paint today and the gaskets are still on the engine side for the most part but a few pieces a couple inches long are still on the covers here and there that ripped (maybe in 2 spots on each cover). D
do you think this will create a leak? I really would like to avoid waiting for new gaskets to come in off the ebays and scraping the old ones off.
Or maybe just a little black rtv along the edges of the rips so it makes it whole again when bolted up?
thanks guys.
thanks guys.
79 Honda CB650
81 Honda CX500
- Powerstroke_fan
- Thank you received: 83
07 Nov 2012 09:34 #557364
by Powerstroke_fan
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Replied by Powerstroke_fan on topic clutch and generator cover gaskets
You might try some type of sealant. But most likely it will leak. But at least you could ride it till your new gaskets come.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- jbeebe1
07 Nov 2012 10:27 #557368
by jbeebe1
79 Honda CB650
81 Honda CX500
Replied by jbeebe1 on topic clutch and generator cover gaskets
i'm just going to get the gaskets off ebay and do it right. I'm an idiot sometimes and get inpatient.
79 Honda CB650
81 Honda CX500
- Motor Head
- Thank you received: 391
07 Nov 2012 10:47 #557371
by Motor Head
Replied by Motor Head on topic clutch and generator cover gaskets
A roll of material from the store and maybe 10 minutes each to cut them. Riding shortly after, and cost is about $5-$6
