HELP! Quick
- mcmelend
05 Nov 2012 01:06 #557082
by mcmelend
1979 Kz750 Twin.
Behold Asian Ingenuity!
HELP! Quick was created by mcmelend
Hey everyone.
i'm rebuilding my Kz just so i can start riding, not an official rebuild. . .
but i've put rear sets on the bike, but the kick stand is in the way of my shifting ability. Any suggestions? I want the cheapest and fastest solution please. I need about 4 inches of clearance for my toe to operate the shift lever.
Thanks!
Thanks!
1979 Kz750 Twin.
- trianglelaguna
- Thank you received: 235
05 Nov 2012 01:31 #557084
by trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
Replied by trianglelaguna on topic HELP! Quick
pictures
1976 KZ900
2003 ZX12R
2007 FZ1000
- Thank you received: 2829
05 Nov 2012 02:12 - 05 Nov 2012 11:15 #557089
by 650ed
Replied by 650ed on topic HELP! Quick
Last edit: 05 Nov 2012 11:15 by 650ed.
- Thank you received: 2098
05 Nov 2012 10:56 - 05 Nov 2012 10:57 #557104
by Patton
Replied by Patton on topic HELP! Quick
Click >
1979 kz750 twin?
Including information about bike year and model is helpful to viewers and usually elicits better responses.
It's easy to put the information in your signature where it shows in all posted messages, past and future.
And may be changed whenever and as often as desired.
If wanting a signature showing information about the bike in posted messages, it's easy to do. Here's how:
Attachment addsig.jpg not found
Last edit: 05 Nov 2012 10:57 by Patton.
- mcmelend
05 Nov 2012 11:15 #557106
by mcmelend
1979 Kz750 Twin.
Replied by mcmelend on topic HELP! Quick
Thank you Patton for the image help. I needed to change that, and put a signature.
i don't have pics of the rear control on yet, but i'll note on this one picture that where the rear passenger pegs go is where my rearsets are. I thought putting a rear control on would solve the kickstand in the way problem, but it hasn't.
2 options i've thought of. 1, move the kickstand forward (but that'd be hard since i don't have the time to pull the motor) option 2, move the rearset position (cut the rear passanger bracket and reweld in new location.
1979 Kz750 Twin.
- wireman
- Thank you received: 299
05 Nov 2012 12:07 #557114
by wireman
Replied by wireman on topic HELP! Quick
Would flipping the shifter backwards make it easier for you?
Without seeing the rearsets its hard to tell what the problem is.
- 4TheKZ1000
- Visitor
05 Nov 2012 16:50 #557138
by 4TheKZ1000
Replied by 4TheKZ1000 on topic HELP! Quick
Im sorry I cant speak on your issue...
I was also wanting to go to (rear sets) and wondered if this was going to be a problem for me also....78 A2A Frame.
Thanks, Spencer
Thanks, Spencer
- steell
05 Nov 2012 17:06 #557140
by steell
Replied by steell on topic HELP! Quick
If the bike in the pic is the one in your sig, then your sig needs to say "1980 KZ750G".
Why in the world are you mounting the footpegs so far back? Your toes are going to end up pointing at the ground. They should be mounted on the backside of the rear down tube ideally.
No matter where you mount them you'll need shifter linkage, and that will take care of your clearance problem.
Word of warning, if you move your seating position rearward you'll shift weight to the rear and unload the front tire, which means it loses traction in a turn and washes out, thus a low side and your butt sliding along the pavement. Been there, done that, broke two ribs in the process.
- mcmelend
05 Nov 2012 17:30 #557150
by mcmelend
1979 Kz750 Twin.
1. all the documents, and down tube markings say that the bike is a 79 Kz750
2. I don't plan on moving the seating position backward, i plan to just add a seat with a hump on it. so essentially i will be in the same balance point.
3. I have a linkage kit, but that doesn't help clear the kick stand. I think i'm going to cut and remount the stand further forward. Seems to be my only option.
Anyone have pics of rearmounts on their bike also picturing the kickstand up?
THanks guys !
THanks guys !
1979 Kz750 Twin.
- les holt
- Thank you received: 288
05 Nov 2012 17:58 #557152
by les holt
Replied by les holt on topic HELP! Quick
Take a look at ramtough's build, he had to move his kickstand forward to clear his shifter setup. It's a look build thread but worth the look!
I believe it's titled "thrown together till winter"
Les
Les
