Replacing head on 77 kz1000
- 771000LTD
02 Nov 2012 14:40 #556815
by 771000LTD
Replacing head on 77 kz1000 was created by 771000LTD
Hello,Can anyone tell me if I can use a head of a later model(79-81)engine if i use the cams from the 77 head that is on the bike now?I figure i will also have to use a 77-78 cam chain.
Also what does a "j" motor model mean?
Thanks
Thanks
- 4TheKZ1000
- Visitor
02 Nov 2012 15:01 - 02 Nov 2012 15:10 #556819
by 4TheKZ1000
Replied by 4TheKZ1000 on topic Replacing head on 77 kz1000
Hello....whats wrong with the head you have? Might be able to fix it.
Just rem thinking you can purchase a 30+ year old used head...bolt it on and life is all good dosent happen offen if at all.
A reconditioned bolt-up head that will give 10's of thousands of miles could run $700 +
79-80 are pre J heads. The problem you can face is the crank. There are two cranks....one has a 15 tooth gear that drives a 122 link chain to run cams.
one crank has a 16 tooth gear that drives a 124 link chain to run cams. These are regularly found in 79-80 engines. They were called emission head. The markII engine along with some LTD models had the 16t crank and emission heads.
The J-head 1981-up. You have to do some tweeking to use on a KZ motor. I know compression ratio is on of the problems.
Last edit: 02 Nov 2012 15:10 by 4TheKZ1000.
- Powerstroke_fan
- Thank you received: 83
02 Nov 2012 21:15 #556848
by Powerstroke_fan
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Replied by Powerstroke_fan on topic Replacing head on 77 kz1000
Yes you can run a 79-80 head on your 77. Just need to make sure you use your orignal cam sprockets that came off the 77 head. Like 4thekz1000 said theres a diffrence in the years. Also you wont need to use a diffent chain unless yours is wore or stretched. I believe the only 81 models that you can use are police bike engines. A easy way to tell if its a j head is to look and see if theres a bolt running thru the valve cover cam end cap. If there is its a j model head. And J model heads require special adpters to make it work on a earlier kz.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
