81 kz550 ltd exhaust collars and carbs.
31 Oct 2012 19:20 #556599 by shockman54
81 kz550 ltd exhaust collars and carbs. was created by shockman54
i have two problems with my bike right now, one, the exhaust doesn't have a very tight fit to the engine block. i was wondering if there was any gaskets other than the two rounded pieces that i could get. the second issue is the carbs are overflowing from the drainage tubes on the bottom. i tightened the screws that block the drains, but it still overflows. the floats should be set correctly, so i was thinking it may be the float needles, any input? thanks guys.
ps, here is everything that i've done so far and a beginning shot.
01 Nov 2012 09:16 - 23 Jan 2013 12:09 #556657 by martin_csr
Replied by martin_csr on topic 81 kz550 ltd exhaust collars and carbs.
never mind - misread doh
Last edit: 23 Jan 2013 12:09 by martin_csr.
01 Nov 2012 14:07 #556684 by Patton
Replied by Patton on topic 81 kz550 ltd exhaust collars and carbs.
This link includes a free service manual download, courtesy of KZr member loudhvx:
home.comcast.net/~loudgpz/GPZweb/Mnls/Mnls.html
Good Fortune! :)
The following user(s) said Thank You: shockman54
01 Nov 2012 16:04 #556692 by shockman54
Replied by shockman54 on topic 81 kz550 ltd exhaust collars and carbs.
hey martin_csr, yes, not the 4 collars, but the 8 half moon ones that you are also in there. like a rounded piece of sheet metal with a lip on the end. i already have the manual, but it doesn't say anything (that i can see) about the gas leaking out of that spot specifically. this is the first kawasaki that i've worked on, it was 2 yamahas before that.
01 Nov 2012 20:10 - 01 Nov 2012 20:12 #556714 by Patton
shockman54 wrote: hey martin_csr, yes, not the 4 collars, but the 8 half moon ones that you are also in there. like a rounded piece of sheet metal with a lip on the end. i already have the manual, but it doesn't say anything (that i can see) about the gas leaking out of that spot specifically. this is the first kawasaki that i've worked on, it was 2 yamahas before that.
Click here > www.z1enterprises.com/ItemDetails.aspx?i...50&item=EM13-87826-1
Good Fortune! :)
Last edit: 01 Nov 2012 20:12 by Patton.
02 Nov 2012 04:44 #556769 by shockman54
thanks so much patton, i couldn't find those anywhere. i'll check in the morning to make sure they aren't in there. any ideas on the gas leak?
