valves too tight, help ordering shims needed
30 Oct 2012 20:43 #556449 by gixxerfiend
So Ive finally got around to checking the clearences and I have some very tight ones. This is the first time I have ever done this but I followed the manual exactly then double checked measurements.
1. .178
2. .076
3. .102
4. less then .038
5. .127
6. less then .038
7. .063
8. less then .038
I believe I can figure out what to do with most of them but what would you do about the really tight ones? On 4, 6, and 8 I couldnt even get the smallest feeler in.
2006 GSXR 1000
2005 CBR 600rr
1977 KZ 650
30 Oct 2012 21:05 #556451 by 650ed
No problem; just install the shims called for in the valve adjustment chart in the Kawasaki Service Manual. Ed
31 Oct 2012 20:32 - 31 Oct 2012 20:36 #556611 by gixxerfiend
Replied by gixxerfiend on topic valves too tight, help ordering shims needed
Ok I have the shims out and plan on ordering from Z1 tomorrow, does this sound right?
clearance current shim shim needed
1 .178 265 2.70
2 .076 275 2.65
3 .102 Good
4 <.038 265 2.50-2.55 thinking 2.55?
5 .127 Good
6 <.038 270 2.55-2.60 thinking 2.60?
7 .063 270 2.60
8 <.038 260 2.45-2.50 thinking 2.50?
Ive read the write up someone had on here that says that for peak performance you want them as near to .10 if possible so the 2 that are in spec but are a little on the loose\tight side Im gonna change to see what I get. What should I do about the ones that I couldnt get the .038 feeler in? go a full .10 under current shim? I dont understand why the manual puts these into 2 different size shims on the graph. Thx for the help, I think I might be overthinking this because of the fact that I thought it would be harder or what? I also realize I can use some of the used shims instead of ordering
2006 GSXR 1000
2005 CBR 600rr
1977 KZ 650
Last edit: 31 Oct 2012 20:36 by gixxerfiend. Reason: numbers
31 Oct 2012 22:29 #556623 by 650ed
According to the KZ650 manual it looks like those should get you within spec. Check after installing to see if further adjustment is needed. Do 1 cam at a time. ;) Ed
