!981 kawasaki CSR cam plugs
- Jw51-123
30 Oct 2012 16:12 #556409
by Jw51-123
!981 kawasaki CSR cam plugs was created by Jw51-123
Hello I have a 1981 CSR 1000 M1 and need to replace the cam plugs. I have purchased a new gasket and plugs . I need to the the torque requirements for the valve cover . Does anyone have the clymer manual specs? Also the tech at Z1 told me to keep it dry and clean .What are your thoughts?
JW51-123
JW51-123
- wireman
- Thank you received: 299
30 Oct 2012 16:28 #556412
by wireman
Replied by wireman on topic !981 kawasaki CSR cam plugs
On the valve cover I always just start in center and work my way out to each side to keep from warping the cover,I dont worry about torquing them just use a 3/8 drive ratchet.
I also use my old stand by copper coat on both sides of the papar gasket,a little clear ryv smeared across the bottem of the cam plugs generally doesnt hurt either(just a little so it doesnt squeeze out inside of motor)
- RonKZ650
- Thank you received: 240
30 Oct 2012 18:18 #556428
by RonKZ650
Replied by RonKZ650 on topic !981 kawasaki CSR cam plugs
Use 3-bond or Yamabond #4 on the plugs for best results. No need to put sealer on the gasket. I think the spec for torque is 5.5ft/Lb or 66 Inch/Lb
- Thank you received: 2829
30 Oct 2012 21:09 #556453
by 650ed
That's the same as I see in my manual. Ed
Replied by 650ed on topic !981 kawasaki CSR cam plugs
RonKZ650 wrote: Use 3-bond or Yamabond #4 on the plugs for best results. No need to put sealer on the gasket. I think the spec for torque is 5.5ft/Lb or 66 Inch/Lb
- Motor Head
- Thank you received: 391
30 Oct 2012 21:54 #556465
by Motor Head
Replied by Motor Head on topic !981 kawasaki CSR cam plugs
Download a copy of the service manual for your bike, in my signature. You will need a pdf viewer such as adobe reader to view.
- Jw51-123
31 Oct 2012 12:41 #556540
by Jw51-123
Replied by Jw51-123 on topic !981 kawasaki CSR cam plugs
Thank you everyone for your information. All the information you gave me is greatly appreciated and I can't thank you all enough!!!! Thanks JW51-123
